Eclipse 3.0 M8, Ant plugin, Could not find one or more classes [message #152912] |
Wed, 07 April 2004 01:08  |
Originally posted by: anony_java.anon.foobar
I am using Eclipse 3.0M8 on Windows XP.
The Ant plugin in Eclipse 3.0 M8 is not configured properly.
When I try to run an Ant build script inside of Eclipse, I see
this error:
Could not find one or more classes: "org.apache.tools.ant.BuildException"
I looked at the Ant configuration.
Windows ---> Preferences --> Ant --> Runtime --> Classpath
I see this:
Ant Home Entries (c:\eclipse\plugins\org.apache.ant_1.6.1)
/c:/eclipse/plugins/org.apache.ant_1.5.4/lib/ant.jar
/c:/eclipse/plugins/org.apache.ant_1.5.4/lib/optional.jar
/c:/j2sdk1.4.2_02/lib/tools.jar
I've got Ant plugin 1.6.1 and it is trying to load the Ant 1.5.4 jar files
My plugins folder, c:\eclilpse\plugins, contains a subdirectory:
The org.apache.ant_1.5.4 subdirectory does not exist
Re: Eclipse 3.0 M8, Ant plugin, Could not find one or more classes [message #153067 is a reply to message #152936] |
Wed, 07 April 2004 10:27   |
I think I know how my environment got into this state.
Prior to installing 3.0 M8, I was using 3.0 M6 on this computer.
Using 3.0 M6, I created a workspace called c:\myworkspace
Prior to installing 3.0 M8, I removed 3.0 M6 from
my system ( rm -rf c:\eclipse )
After I installed 3.0 M8, I told Eclipse to use my existing workspace,
c:\myworkspace
Darin Swanson wrote:
> I have not seen this state in my testing.
> You best bet is use the "Restore Defaults" functionality or to make use of
> the Set Ant Home...
> Setting only the ant.jar and the ant-launcher.jar does not give you the full
> set of required Ant JARs.
> HTH
> Darins
> "Anony" <anony_java@anon.foobar> wrote in message
> news:c503bn$pn9$1@eclipse.org...
>>I found a workaround:
>>1) Windows ---> Preferences --> Ant --> Runtime --> Classpath
>>2) Ant Home Entries
>> Remove: /c:/eclipse/plugins/org.apache.ant_1.5.4/lib/ant.jar
>> Remove:
>> Add: /c:/eclipse/plugins/org.apache.ant_1.6.1/lib/ant.jar
>> Add:
>> /c:/eclipse/plugins/org.apache.ant_1.6.1/lib/ant-launcher.ja r
>>>this error:
>>>I see this:
> files
Re: Eclipse 3.0 M8, Ant plugin, Could not find one or more classes [message #153075 is a reply to message #153067] |
Wed, 07 April 2004 11:38  |
As I stated in the Ant mailing list, please log a bug report with the
relevant details.
And there is no need to double post. I would suggest that the newsgroup is
the best place for these types of discussions.
Darins
news:c512q4$3au$1@eclipse.org...
> c:\myworkspace
of
> > the Set Ant Home...
full
> > HTH
> > Darins
> >>2) Ant Home Entries
> >> Remove:
> >> Remove:
> >> Add:
> >>>this error:
> >>>I see this:
> > files
FUDForum. Page generated in 0.04375 seconds
