Home » Eclipse Projects » Eclipse Platform » How to programatically refresh a folder from a plugin?
How to programatically refresh a folder from a plugin? [message #152790] Tue, 04 November 2003 11:40 Go to next message
Originally posted by: FLawlor.TMRS.org
I wrote a plugin and it tries to do a refresh on a directory to which I
have added files using Window's explorer (simplified):
IWorkspaceRoot workspaceRoot = ResourcesPlugin.getWorkspace().getRoot();
IProject project = workspaceRoot.getProject("MyProject");
project.open(null);
IFolder folder = project.getFolder("source/foo/bar");
folder.refreshLocal(99, null);
System.out.println("Successfully refreshed.");
This says it runs fine, but
1) The GUI is not refreshed
2) The actions performed by a GUI menu refresh operation are clearly not
performed since it involves a bunch of compiles, which are not happening
in the programatic case.
How do I simulate the GUI menu refresh operation?
-- Frank
Re: How to programatically refresh a folder from a plugin? [message #155122 is a reply to message #152790] Mon, 10 November 2003 18:49 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
Look at the javadoc for refreshLocal. You're passing an illegal value
for the "depth" parameter.
> project.open(null);
> -- Frank
Re: How to programatically refresh a folder from a plugin? [message #155628 is a reply to message #155122] Tue, 11 November 2003 17:48 Go to previous messageGo to next message
John,
Thanks for the response.
I changed it to IFolder.DEPTH_INFINITE, but I still get the same result.
It completes much too quickly and the GUI folder does not appear refreshed.
Any suggestions, references?
Re: How to programatically refresh a folder from a plugin? [message #156022 is a reply to message #155628] Wed, 12 November 2003 17:02 Go to previous message
It sounds like you're now doing the right thing. This is exactly what
the UI refresh action does (org.eclipse.ui.actions.RefreshAction).
Frank wrote:
> John,
Previous Topic:Plugins and Eclipse cvs November 12
Next Topic:Todo list editor?
Current Time: Sat Jul 26 09:28:55 EDT 2025
Powered by FUDForum. Page generated in 0.06333 seconds
