Home » Modeling » GMF (Graphical Modeling Framework) » Writing to model
Writing to model [message #152751] Mon, 01 October 2007 10:05 Go to next message
Originally posted by: kmcglinn.gmail.com
Hey Guys,
I notice that although I specify a label for my ecore attributes, it seems
that they will not be saved to the xmi file when I save the diagram. Is
there any way to force an xmi attribute to appear in the gmf file?
For example, lets say I have a transition between two nodes with an
attribute "condition"
<containsActivities xsi:type="service:TransformationCondition"
source="//@containsSwimlanes.0/@containsActivities.2"
target="//@containsSwimlanes.0/@containsActivities.1" condition=".."/>
If I had not entered ".." into the model I would not have got:
target="//@containsSwimlanes.0/@containsActivities.1" condition=""/>
But rather
target="//@containsSwimlanes.0/@containsActivities.1"/>
Which crashes my parser...any way to force the attribute to be created,
empty or not?
Guy.
Re: Writing to model [message #152761 is a reply to message #152751] Mon, 01 October 2007 10:09 Go to previous message
Guy,
EMF will only save attributes for which eIsSet is true so generally you
must set the value if you want it to be saved. If you use
XMLResource.OPTION_KEEP_DEFAULT_CONTENT as a save option, then features
with an explicit non-null default will serialize that default.
Guy Incognito wrote:
> Hey Guys,
> seems that they will not be saved to the xmi file when I save the
> diagram. Is there any way to force an xmi attribute to appear in the
> gmf file?
> But rather
> created, empty or not?
> Guy.
Previous Topic:Reformatted: Re: Deadlocks occur after a TransactionalEditingDomain.runExclusive(...) call was inter
Next Topic:DiagramEditPart HEELP
Current Time: Sat Jul 26 09:28:49 EDT 2025
Powered by FUDForum. Page generated in 0.06197 seconds
