Home » Modeling » GMF (Graphical Modeling Framework) » Reformatted: Re: Deadlocks occur after a TransactionalEditingDomain.runExclusive(...) call was inter
Reformatted: Re: Deadlocks occur after a TransactionalEditingDomain.runExclusive(...) call was inter [message #152637] Sat, 29 September 2007 15:20 Go to next message
Sorry for the malformatted post. Second try:
See my stack trace here:
<http://page.mi.fu-berlin.de/kamenzky/forum/a/StackTrace>
And here the text of my last post again:
I compared the threads while working correctly and while hanging.
Like you see in this picture:
<http://page.mi.fu-berlin.de/kamenzky/forum/a/editing.png>
I found three worker threads waiting:
Worker-0, Worker-1, Worker-3
Their stack is exactly the same. Unfortunately I still can't see
which kind of thread theyreally are. Two of those three are
definitely my own threads which do the validation. I could
executejust one validation thread but the outcome is still the same.
I still don't know for which purpose the third thread is which is
(I think) represented in the dialog as "Waiting User Operation".
A big difference I found in the main thread. While hanging its
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2390)is
not idling but waiting whereelse!
Any ideas?
Your help is highly appreciated!
Nicolai
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
Re: Reformatted: Re: Deadlocks occur after a TransactionalEditingDomain.runExclusive(...) call was i [message #152745 is a reply to message #152637] Mon, 01 October 2007 10:03 Go to previous message
Hi, Nicolai,
The main thread is blocked waiting for one of the Worker-n threads to
acquire a lock on its behalf (this strategy is employed because it allows
the UI thread to run a nested event loop and show the blocked-user-action
dialog).
The problem is, that I don't see any stack trace showing a thread that owns
a transaction lock. So, it looks like the editing domain thinks it is
locked by a thread that either is no longer running or thinks it no longer
has the lock. You mentioned in your other post that some thread was
interrupted while waiting to start a transaction. I suspect that this is
the culprit. It sounds like there is a bug in the interruption of waiting
to start a transaction, but I don't see it by looking at the code.
Why was this validation routine interrupted? Would you be able to provide a
reproducible test case that I can debug to see why this lock isn't being
released that should be?
Christian
> Any ideas?
> Nicolai
Previous Topic:figures for Java swt and swing widgets
Next Topic:Writing to model
Current Time: Mon Jul 14 23:57:10 EDT 2025
Powered by FUDForum. Page generated in 0.06233 seconds
