Home » Language IDEs » Java Development Tools (JDT) » RCP and M8
RCP and M8 [message #152407] Mon, 05 April 2004 13:15 Go to next message
Hey,
Building a stand alone RCP application with M8 doesn't seem to work.
Everything works fine until you try to launch the application using the M8
provided Eclipse.exe.
Launching with a clean 'configuration' directory results in the included
log message (see below).
The log message indicates a dependency on org.eclipse.ui.ide, which we
explicitly *don't* want to include.
Is there something in Eclipse.exe that would cause the dpendancy on
org.eclipse.ui.ide?
-Mitch
!SESSION Apr 05, 2004 10:18:05.250
java.version=1.4.1_01
!ENTRY org.eclipse.osgi Apr 05, 2004 10:18:05.250
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Unable to locate application extension:
org.eclipse.ui.ide.workbench
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:263)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:239)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:117)
at org.eclipse.core.launcher.Main.basicRun(Main.java:267)
at org.eclipse.core.launcher.Main.run(Main.java:692)
at org.eclipse.core.launcher.Main.main(Main.java:676)
Re: RCP and M8 [message #152601 is a reply to message #152407] Mon, 05 April 2004 22:37 Go to previous message
Originally posted by: pascal.ibm.canada
It seems that you forgot to specify the application to run (-application
appId)
PaScaL
Mitch Christensen wrote:
> Hey,
> org.eclipse.ui.ide?
> -Mitch
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 1
> at
> at
> at
> at
> at
Previous Topic:M8: Usability with multiple editors
Next Topic:Reformatting only part of a source file?
Current Time: Fri Jul 18 06:01:39 EDT 2025
Powered by FUDForum. Page generated in 1.35783 seconds
