Home » Language IDEs » ServerTools (WTP) » How to use DoubleClickListener in TableViewer
How to use DoubleClickListener in TableViewer [message #152392] Thu, 15 December 2005 01:13 Go to next message
Originally posted by: amitgolwala.gmail.com
hi all,
I have a TableViewer with 4 columns. I have added a DoubleClickListener
event on the same viewer but when I double click on any other column
except for the first column, nothing happens. However, if I double click
on the first column then, that do result in occurence of the intended
output. I have extended IViewPart and implemented IDoubleClickListener
for this viewer.
ne suggestions or help will be highly appericiated !!
thanks a lot for reading this post !!
Amit !!
Re: How to use DoubleClickListener in TableViewer [message #152530 is a reply to message #152392] Thu, 15 December 2005 13:51 Go to previous message
> for this viewer.
You would reach a wider audience by posting in eclipse.platform.
You should also include some details such as which style bits you're
using when you create the viewer, whether you're using cell editors,
and if you have any other listeners (like mouse listeners) in place.
- Nitin
Previous Topic:WTP 1.0RC4 and <distributable/> tag
Next Topic:Word wrap
Current Time: Thu Jul 17 20:07:10 EDT 2025
Powered by FUDForum. Page generated in 0.03923 seconds
