Home » Language IDEs » ServerTools (WTP) » WTP-1.0RC4 - "Run On Server" error
WTP-1.0RC4 - "Run On Server" error [message #152376] Wed, 14 December 2005 19:10 Go to next message
Originally posted by: lnite.nowhere.com
I'm giving WTP-1.0RC4 a test drive and I'm running into a problem my
test project's automatic building process, when attempting a "Run on
Server".
The Ant build fails with the following error:
BUILD FAILED
/home/lnite/eclipse_wtp/plugins/org.eclipse.jst.server.gener ic.serverdefinitions_1.0.0/buildfiles/oracle.10.1.3.xml:66:
The following error occurred while executing this line:
/home/lnite/eclipse_wtp/plugins/org.eclipse.jst.server.gener ic.serverdefinitions_1.0.0/buildfiles/oracle.10.1.3.xml:38:
/home/lnite/workspace_wtp/.metadata/.plugins/org.eclipse.cor e.resources/.projects/DemoJSP/org.eclipse.jst.server.generic .serverdefinitions/org.eclipse.jst.j2ee.server:DemoJSP
not found.
Checking the 'oracle.10.1.3.xml' file, I found out that the error was
caused by what seems to be a faulty evaluation of ${module.dir}.
I couldn't find where this property is being defined, but I'm assuming
it's supposed to be a directory path, which it apparently is not. In the
above case, ${module.dir} =
" /home/lnite/workspace_wtp/.metadata/.plugins/org.eclipse.cor e.resources/.projects/DemoJSP/org.eclipse.jst.server.generic .serverdefinitions/org.eclipse.jst.j2ee.server:DemoJSP "
which isn't a real directory. The correct value would appear to be:
" /home/lnite/workspace_wtp/.metadata/.plugins/org.eclipse.cor e.resources/.projects/DemoJSP/org.eclipse.jst.server.generic .serverdefinitions/DemoJSP "
I haven't tried recreating this on other app-servers.
- Alvin
Re: WTP-1.0RC4 - "Run On Server" error [message #152483 is a reply to message #152376] Thu, 15 December 2005 10:29 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Alvin,
seems to be a Linux matter.
Search for the post "Re: Attemp to create JBoss4-Serverdef for M9" from
11.12.2005 00:55 by GS, he has the same problem with a JBoss serverdef.
But I cannot provide a solution to this...
Wolfgang
Alvin Pillay wrote:
> Server".
> BUILD FAILED
> not found.
> - Alvin
Re: WTP-1.0RC4 - "Run On Server" error [message #152588 is a reply to message #152376] Thu, 15 December 2005 16:52 Go to previous messageGo to next message
Originally posted by: gercan.removeThis.acm.org
This may be a Linux issue, please open a bug report so that it gets tackled.
Gorkem.
Alvin Pillay wrote:
> Server".
> BUILD FAILED
> not found.
> - Alvin
Re: WTP-1.0RC4 - "Run On Server" error [message #152626 is a reply to message #152483] Fri, 16 December 2005 12:44 Go to previous messageGo to next message
Wolfgang Knauf wrote:
> Hi Alvin,
> Wolfgang
> Alvin Pillay wrote:
>> Server".
>> BUILD FAILED
>> not found.
>> the above case, ${module.dir} =
JBoss4 have the same problem
Uno Engborg
Re: WTP-1.0RC4 - "Run On Server" error [message #152640 is a reply to message #152588] Fri, 16 December 2005 15:31 Go to previous messageGo to next message
Originally posted by: cbosma.tecmasters.com
I can confirm this problem as well with RC4 on a Linux box, for both an
Oracle OC4J and JBoss 4 instance (using the JBoss 4 serverdef found in
this newsgroup). I haven't found a bug report on this, though; if you
like, I'll open one.
Craig
On Thu, 15 Dec 2005 15:52:35 -0600, Gorkem Ercan
> tackled.
> Gorkem.
> Alvin Pillay wrote:
>> Server".
>> BUILD FAILED
>> not found.
>> - Alvin
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: WTP-1.0RC4 - "Run On Server" error [message #152682 is a reply to message #152640] Sat, 17 December 2005 03:53 Go to previous messageGo to next message
Please do, I do not have a linux box available right now.
Gorkem.
> Craig
>> tackled.
>> Gorkem.
>> Alvin Pillay wrote:
>>> Hi,
>>> Server".
>>> BUILD FAILED
>>> not found.
>>> was caused by what seems to be a faulty evaluation of ${module.dir}.
>>> assuming it's supposed to be a directory path, which it apparently is
>>> not. In the above case, ${module.dir} =
>>> - Alvin
> --Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: WTP-1.0RC4 - "Run On Server" error [message #152717 is a reply to message #152483] Sat, 17 December 2005 17:50 Go to previous messageGo to next message
--------------060309050407000108090309
> Hi Alvin,
In JBoss4 for RC4 on Linux it seams that the ${modules.dir} property
contains a org.eclipse.jst.j2ee.server directory too much at the end of
the path in the <zipfileset> sections of jboss40.xml.
I have replaced the ${modules.dir} with
"${project.working.dir}/${module.name}" and it seam to work.
Could anyone tell if this have some side effects on other platforms?
I have attached my altered jboss40.xml if you like to test it.
Uno Engborg
Content-Type: text/xml;
name="jboss40.xml"
Content-Disposition: inline;
filename="jboss40.xml"
<project name="deployextension" default="deploy.j2ee.web" basedir=".">
<target name="deploy.j2ee.web">
<jar destfile="${project.working.dir}/${module.name}.war">
<!-- <zipfileset dir="${module.dir}"> -->
<zipfileset dir="${project.working.dir}/${module.name}">
<include name="**/*.*"/>
<exclude name="**/*.war"/>
</zipfileset>
</jar>
<move file="${project.working.dir}/${module.name}.war" todir="${server.publish.dir}"/>
</target>
<target name="deploy.j2ee.ejb">
<jar destfile="${project.working.dir}/${module.name}.jar">
<exclude name="**/*.jar"/>
</zipfileset>
</jar>
<move file="${project.working.dir}/${module.name}.jar" todir="${server.publish.dir}"/>
</target>
<target name="deploy.j2ee.ear">
<jar destfile="${project.working.dir}/${module.name}.ear">
<exclude name="**/*.java"/>
</zipfileset>
</jar>
<move file="${project.working.dir}/${module.name}.ear" todir="${server.publish.dir}"/>
</target>
<target name="undeploy.j2ee.web">
<delete file="${server.publish.dir}/${module.name}.war"> </delete>
</target>
<target name="undeploy.j2ee.ejb">
<delete file="${server.publish.dir}/${module.name}.jar"> </delete>
</target>
<target name="undeploy.j2ee.ear">
<delete file="${server.publish.dir}/${module.name}.ear"> </delete>
</target>
</project>
--------------060309050407000108090309--
Re: WTP-1.0RC4 - "Run On Server" error [message #154051 is a reply to message #152717] Wed, 28 December 2005 10:26 Go to previous message
Hi Uno,
thanks for the update.
I create a linux version of the plugin file with your proposal and put it here:
http://www.informatik.fh-wiesbaden.de/~knauf/SWTVertiefung20 05/jboss/allgemein/org.eclipse.jst.server.jboss_1.0.0_Linux. jar
Would be great if someone could verify it.
Wolfgang
>> Hi Alvin,
>> from 11.12.2005 00:55 by GS, he has the same problem with a JBoss
>> serverdef.
> Regards
> Uno Engborg
Previous Topic:Generated JSP code
Next Topic:Installing WTP 1.0 on Eclipse SDK3.2M4
Current Time: Fri Jul 25 00:41:56 EDT 2025
Powered by FUDForum. Page generated in 0.04807 seconds
