Re: WTP Question [message #152368 is a reply to message #152345] |
Wed, 14 December 2005 22:52 |
Jonathan Barnes Messages: 10 Registered: July 2009 |
As far as I know the place to modify them is in the .wtpmodules file itself. I
a haven't seen any UI to manage that info, and don't think it exists. I have,
however modified that file without incident.
Apparently in the 1.0 versions of WTP the .wtpmodules file has been replaced by
other config files in the .settings folder. I don't know the format of these
new files or where any of that info exists, but would not recommend spending too
much time getting to understand the .wtpmodules file as it will soon disappear.
Fabio Mancinelli wrote:
> Hello all.
> Maybe this is a silly question but I cannot figure out where, in the IDE
> menus and dialogs, it is possible to change the information that is
> stored in the .wtmodules of a Dynamic Web Project. In particular, the
> context-root property of the module.
> Moreover, in the .wtpmodules file there are also several wb-resource
> tags with deploy-path/source-path attributes which can be useful when
> you want to maintain a non-standard structure of your project and deploy
> the files in the right places. Again, I haven't found any place in the
> IDE where this information could be modified.
> Any hint?
> Thank you,
> Fabio
Changing webapp's context root (was Re: WTP Question) [message #152450 is a reply to message #152424] |
Thu, 15 December 2005 14:41 |
>> itself. I a haven't seen any UI to manage that info, and don't think
>> it exists. I have, however modified that file without incident.
>> replaced by other config files in the .settings folder. I don't know
>> the format of these new files or where any of that info exists, but
>> would not recommend spending too much time getting to understand the
> I have installed WTP 1.0RC4 and, as you said, the .wtpmodules file has
> been moved and renamed in the .settings folder. In the .component file I
> can find all the information that was present in the .wtpmodules (i.e.,
> the application context-root and various deployment paths). Still there
> is no way to alter this information from the IDE.
> It seems *really* strange to me that a so trivial feature like changing
> the context-root after project creation has not been implemented through
> an IDE accessible way.
Strange indeed. Is there a bug filed about this?
Daniel Serodio
FUDForum. Page generated in 0.03474 seconds
