Home » Language IDEs » C / C++ IDE (CDT) » Debugging Problems
Debugging Problems [message #152232] Wed, 24 August 2005 20:37 Go to next message
Originally posted by: ozbod_333.hotmail.com
Hi all,
I am trying to use CDT3.0 on Linux AS3.0 with GDB 5.3.90-0.20030710.40rh to
debug a multi-threaded application
that makes numerous calls to shared libraries. I am having a number of
issues with the debugger under CDT which I am
not having if I run 'ddd' which is strange as both tools sit on top of
GDB??.
Problem 1: The CDT debugger refuses to see the source code for a given
shared library. I have added all the paths and
locations as required but still it won't let me step into that area of code.
'ddd' finds all the code fine without having to setup
a single thing.
Problem 2: The application is multithreaded and when I allow the application
to run on and create all the threads the
debugger won't stop on any breakpoint even though I know the threads are
accessing some of the methods with bp's
and then eventually cannot 'attach' to the thread and get any info at all,
i.e. I cannot even get the debugger to pause
the thread. Again all the above can be done fine with 'ddd'.
Our organisation is really keen to adopt Eclipse and CDT as our defacto C++
development IDE but it is hard to
convince people when it cannot perform as well as other (non-integrated)
tools such as 'ddd'. Thus any help anyone
can give in overcoming the above problems would be greatly appreciated.
ozbod
Re: Debugging Problems [message #152289 is a reply to message #152232] Thu, 25 August 2005 11:58 Go to previous messageGo to next message
> code. 'ddd' finds all the code fine without having to setup
> a single thing.
The CDT debugger doesn't block stepping into a library. It simply sends the
"step" command to gdb. There could be different reasons why gdb can not step
into a function, but I don't think the source lookup path is one of them.
The source lookup is performed after the step operation is accomplished.
> application to run on and create all the threads the
I can only guess that the breakpoints are not set correctly. When you start
a debug session , the debugger tries to identify the breakpoints that belong
to the program being debugged. The source lookup path is used for these
purposes. If a breakpoint is set to the debug session the breakpoint's image
contains a check mark.
"exquisitus" <ozbod_333@hotmail.com> wrote in message
news:dej3su$61t$1@news.eclipse.org...
> Hi all,
> to debug a multi-threaded application
> GDB??.
> a single thing.
> C++ development IDE but it is hard to
> Cheers,
> ozbod
Re: Debugging Problems [message #152335 is a reply to message #152232] Fri, 26 August 2005 02:44 Go to previous message
Originally posted by: grkoma.nospamgmail.com
I had similar problem some time ago, try to set source lookup path. If
it is not set correctly, breakpoints are showed in editor, but debugger
wont stop on it. Setting source lookup path will solve this problem.
Marko
exquisitus wrote:
> Hi all,
> GDB??.
> a single thing.
> Cheers,
> ozbod
Previous Topic:Why code completion is so slow?
Next Topic:Export workspace/projects settings ?
Current Time: Sun Jul 27 06:31:38 EDT 2025
Powered by FUDForum. Page generated in 0.05863 seconds
