Home » Archived » BIRT » Problem rendering a report with an xml file as a data source : truncated data text
| Problem rendering a report with an xml file as a data source : truncated data text [message #152188] |
Mon, 10 April 2006 04:36  |
Originally posted by: ludovic.chane-won-in.atosorigin.com
Hi all,
I have a problem when I render my birt report. Some data of my dataSet
is truncated !!!
My report consists in an xml data source and a simple dataSet. The
dataSet matches an xpath and collect some text. Those texts are more or
less long and after n rows (dataRows), the text of the n+1 dataRow is
truncated. Then, the following rows are okay but p rows after, my text
is truncated and ... etc
It seems to be a problem of cache memory. This problem appears not only
on the report but already in the previsualisation of the dataSet in
eclipse. Maybe, some dataSet parameters exist but I didn't find them.
The only relevant parameters I found were cachedMetaData and
cachedRowCount. I don't know how to use the cachedMetaData parameter and
the cachedRowCount parameter can't resolve my problem.
I'm lost, please help me ... and forgive me for my poor english
Ludo
ps : i can join the complete log if you need it
| problem with & character (was Re: Problem rendering a report with an xml file as a data source : [message #152874 is a reply to message #152188] |
Wed, 12 April 2006 05:46   |
Originally posted by: marc.leineweber.icc-gmbh.de
Hi Ludo,
I have a similar problem, the reason in my case is an & character in my text
(I use an XML data source, BIRT 2.0.1) - that character and the end of the
text of the field after that character are truncated. Even the & entity
does not work. Does your text contain an & and if yes, did you find a
workaround or solution to display this character?
Or does anybody else have seen this problem and may provide a solution?
Marc
"Ludovic CWI" <ludovic.chane-won-in@atosorigin.com> schrieb im Newsbeitrag
news:e1d594$eq1$1@utils.eclipse.org...
> Hi all,
> I have a problem when I render my birt report. Some data of my dataSet is
> truncated !!!
> My report consists in an xml data source and a simple dataSet. The dataSet
> matches an xpath and collect some text. Those texts are more or less long
> and after n rows (dataRows), the text of the n+1 dataRow is truncated.
> Then, the following rows are okay but p rows after, my text is truncated
> and ... etc
> It seems to be a problem of cache memory. This problem appears not only on
> the report but already in the previsualisation of the dataSet in eclipse.
> Maybe, some dataSet parameters exist but I didn't find them. The only
> relevant parameters I found were cachedMetaData and cachedRowCount. I
> don't know how to use the cachedMetaData parameter and the cachedRowCount
> Ludo
| Re: problem with & character (was Re: Problem rendering a report with an xml file as a data sour [message #153159 is a reply to message #152874] |
Thu, 13 April 2006 03:12   |
Hi again,
the behavior I described (everything OK when no special character was in the
text) was shown for a small xml data source and with only one data set
defined. Now, with a more complex report and for that a bigger xml file, I
have the problem as you described it - even without any special character...
Did you find a solution yet? I would appreciate any hint.
Marc
"Marc Leineweber" <marc.leineweber@icc-gmbh.de> schrieb im Newsbeitrag
news:e1ii92$41n$1@utils.eclipse.org...
> Hi Ludo,
> text (I use an XML data source, BIRT 2.0.1) - that character and the end
> of the text of the field after that character are truncated. Even the
> & entity does not work. Does your text contain an & and if yes, did
> you find a workaround or solution to display this character?
> Marc
>> Hi all,
>> truncated !!!
>> truncated. Then, the following rows are okay but p rows after, my text is
>> eclipse. Maybe, some dataSet parameters exist but I didn't find them. The
>> only relevant parameters I found were cachedMetaData and cachedRowCount.
>> I don't know how to use the cachedMetaData parameter and the
>> Regards,
>> Ludo
| Re: problem with & character (was Re: Problem rendering a report with an xml file as a data sour [message #153374 is a reply to message #153159] |
Thu, 13 April 2006 09:17   |
1.First for your problem of & character, you have to put your data
between CDATA brackets : <![CDATA[ blablabla & blablabla ]]> and it will
normally work.
2.I notice the same behaviour you mentionned "Now, with a more complex
report and for that a bigger xml file, I have the problem as you
described it - even without any special character..." but I did not
solve the problem yet. And I don't know how to do for now ... Please
community help us ! ^^
Here some parts of my log :
10 avr. 2006 10:16:50
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement doSetProperty
WARNING: Cannot set statement property.
java.lang.UnsupportedOperationException: IQuery.setProperty( String
propertyName, String propertyValue )
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaOb ject.handleUnsupportedOp(OdaObject.java:278)
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.setProperty(OdaQuery.java:229)
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.d oSetProperty(PreparedStatement.java:154)
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.s etProperty(PreparedStatement.java:136)
org.eclipse.birt.data.engine.executor.DataSourceQuery.addPro perties(DataSourceQuery.java:348)
org.eclipse.birt.data.engine.executor.DataSourceQuery.prepar e(DataSourceQuery.java:303)
org.eclipse.birt.data.engine.impl.PreparedExtendedDSQuery$Ex tendedDSQueryExecutor.prepareOdiQuery(PreparedExtendedDSQuer y.java:277)
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.pre pareExecution(PreparedQuery.java:672)
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.acc ess$000(PreparedQuery.java:498)
org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:225)
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:145)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.execut e(DteDataEngine.java:205)
org.eclipse.birt.report.engine.executor.QueryItemExecutor.op enResultSet(QueryItemExecutor.java:62)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:122)
org.eclipse.birt.report.engine.executor.ReportExecutorVisito r.visitTableItem(ReportExecutorVisitor.java:187)
org.eclipse.birt.report.engine.ir.TableItemDesign.accept(Tab leItemDesign.java:69)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:125)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:89)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:175)
at ExecuteReport.executeReport(ExecuteReport.java:84)
at ExecuteReport.main(ExecuteReport.java:100)
at org.apache.tools.ant.taskdefs.ExecuteJava.run(ExecuteJava.ja va:202)
at org.apache.tools.ant.taskdefs.ExecuteJava.execute(ExecuteJav a.java:134)
at org.apache.tools.ant.taskdefs.Java.run(Java.java:710)
at org.apache.tools.ant.taskdefs.Java.executeJava(Java.java:178 )
at org.apache.tools.ant.taskdefs.Java.execute(Java.java:84)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:275)
at org.apache.tools.ant.Task.perform(Task.java:364)
at org.apache.tools.ant.Target.execute(Target.java:341)
at org.apache.tools.ant.Target.performTasks(Target.java:369)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1216)
at org.apache.tools.ant.Project.executeTarget(Project.java:1185 )
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:40)
at org.apache.tools.ant.Project.executeTargets(Project.java:106 8)
at org.apache.tools.ant.Main.runBuild(Main.java:668)
at org.apache.tools.ant.Main.startAnt(Main.java:187)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:246)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:67)
org.eclipse.birt.data.engine.executor.cache.SmartCache populateData
INFO: memoryCacheRowCount is 20000
10 avr. 2006 10:16:51
INFO: MemoryCache is used
INFO: Time consumed by cache is: 1 second
regards,
Ludo
Marc Leineweber a écrit :
> Hi again,
> Marc
>> Hi Ludo,
>> Regards,
>> Marc
>>> Hi all,
>>> truncated !!!
>>> Regards,
>>> Ludo
| Re: Problem rendering a report with an xml file as a data source : truncated data text [message #155698 is a reply to message #154034] |
Mon, 24 April 2006 09:14  |
Hi Marc,
I didn't thoroughly understand your explanation but thanks to you I
managed to solve my problem. Actually, instead of putting my text into a
node, I put it into an attribute of that node. And it works. But I still
can't understand why there was a truncation before.
So maybe it's what you suggested me. In all cases, I'm very thankful to you.
Ludovic
> Hi Ludovic,
> thank you for the hint, the CDATA soultion works for the special character
> problem. Though I have no general solution for the weird truncation problem
> you described, I avoided the truncation by restructuring my XML data source:
> I had a big level in my XML data tree with lots of attributes put into
> simple nodes, plus some complex nodes (with subnodes) for my "subtables"; I
> divided the big level into smaller portions by adding nodes to collect
> attributes in them, and voilà - it works without any truncation. May be the
> problem will come again when adding more data to the XML file, but I hope
> this approach will work even for more complex data sources.
> I got a (may be similar but) different hint from another newsgroup reader:
> He added new xml tags to move the truncation to this data which he does not
> need, but I did not test it for my case.
> I hope this is of at least little help, regards
> Marc
> news:e1lirn$jut$1@utils.eclipse.org...
>> 1.First for your problem of & character, you have to put your data between
>> CDATA brackets : <![CDATA[ blablabla & blablabla ]]> and it will normally
>> work.
>> report and for that a bigger xml file, I have the problem as you described
>> it - even without any special character..." but I did not solve the
>> problem yet. And I don't know how to do for now ... Please community help
>> us ! ^^
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> regards,
>> Ludo
>>> Hi again,
>>> the text) was shown for a small xml data source and with only one data
>>> set defined. Now, with a more complex report and for that a bigger xml
>>> file, I have the problem as you described it - even without any special
>>> character... Did you find a solution yet? I would appreciate any hint.
>>> Regards,
>>> Marc
>>>> Hi Ludo,
>>>> Regards,
>>>> Marc
>>>> Newsbeitrag news:e1d594$eq1$1@utils.eclipse.org...
>>>>> Hi all,
>>>>> is truncated !!!
>>>>> and the cachedRowCount parameter can't resolve my problem.
>>>>> Regards,
>>>>> Ludo
Current Time: Sat Nov 29 15:08:06 EST 2025
Powered by FUDForum. Page generated in 0.04899 seconds
