Home » Eclipse Projects » GEF » 2nd view for the model
2nd view for the model [message #152025] Sun, 26 September 2004 02:35 Go to next message
Originally posted by: grayzhu.yahoo.com
I am thinking about a GEF application that needs two views for the model,
and hopefully the views can be swaped by a click of a button. For instance,
in the "logic" example, if I want a tabular (table) form listing all the
circuits, gates, inputs and output as the 2nd view. How does the GEF
framework accomodate it?
Thanks!
Re: 2nd view for the model [message #152118 is a reply to message #152025] Mon, 27 September 2004 16:16 Go to previous messageGo to next message
You can use a figure which flips pages and has a page with each type of view
you need. It could use figure.setVisible(boolean)
"ray zhu" <grayzhu@yahoo.com> wrote in message
news:cj5nmr$4ch$1@eclipse.org...
instance,
> Thanks!
Re: 2nd view for the model [message #152343 is a reply to message #152118] Wed, 29 September 2004 01:13 Go to previous messageGo to next message
Thanks Randy for the idea. Since I am a newbie, I may be asking dumb
questions.
By "page", do you meant 1 big figure that's the container for a view? I am
not sure an editpart object would be able to control figures in both views
(pages) so that they can act synchrously.
I came cross the concept of "Layers" in the help, are they something similar
to "Pages", or "Tabs"?
Also, the outline view (tree) provided in the Shapes example and logic
example is essentially 2nd view, but the outline view is less interactive
than the regular view, is it possible to customize the outline view to make
it to show something other than the treeview and fully interactive?
Thanks for your experts' input.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cj9s6j$4v2$1@eclipse.org...
view
model,
> instance,
> > Thanks!
Re: 2nd view for the model [message #152411 is a reply to message #152343] Wed, 29 September 2004 12:49 Go to previous message
Maybe you just need to look at MultiPageEditorPart
news:cjdg1a$433$1@eclipse.org...
> questions.
similar
make
> view
> model,
> > instance,
the
> > > Thanks!
Previous Topic:"Hide" Option in ContextMenu
Next Topic:Migration - How to make my Selection Actions work again
Current Time: Mon Jul 21 23:52:05 EDT 2025
Powered by FUDForum. Page generated in 0.06937 seconds
