Re: Available Extension Points for UML2Tools [message #1154] |
Fri, 17 October 2008 07:41 |
Hi Mat,
We've done something similar a while ago. An overview of the outcome is
presented in http://www.eclipse.org/gmt/epsilon/cinema/GMFWizards2.htm .
Having a look in the source code of the following plugins:
https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.eps ilon/trunk/plugins/org.eclipse.epsilon.ewl.emf
and
https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.eps ilon/trunk/plugins/org.eclipse.epsilon.ewl.gmf
should answer most of your questions.
Dimitrios
mat wrote:
> hello everyone!
> i am currently facing the question on how to add a certain functionality
> to the UML2Tools. the task is the following:
> i was given a tool which can apply graph transformations to ecore based
> models - namely UML models based in the UML2 metamodel. my task is to
> make the functionality of this tool available at the level of the
> UML2Tools. it is supposed to work as follows:
> you do a right click in the appearing graphical editor and the context
> menu includes a point "Patterns" which has a submenu where you can
> select a variety of patterns the selection of which adds a whole
> construct of model objects (for instance a factory pattern).
> my questions are these:
> 1. are there any extension points defined for the UML2Tools directly
> which i could use for that purpose (especially to manipulate the already
> given context menu)?
> 2. if not: in how far would you consider it possible to achieve the task
> by using extension points (hopefully) available through gmf? and which
> ones could that be?
> 3. in how far would you consider those extension points to be avaiable
> in future versions of either UML2Tools or gmf or whatever else they come
> from? because it is essential that the outcome of my work is easily
> tranferable to new versions of eclipse or its plug-ins.
> thanks in advance
> mat
FUDForum. Page generated in 0.07971 seconds
