How to run GEF examples [message #151547] |
Tue, 21 September 2004 05:38  |
Originally posted by: jdelgad.fedro.ugr.es
Hi !!!, I want to run the GEF examples, but I can't. What can I do?
Re: How to run GEF examples [message #151577 is a reply to message #151555] |
Tue, 21 September 2004 11:32   |
Hi again!
When I have created my application, I do the following:
Run > Run As... > Runtime Workbench
and I get the following .log file:
!SESSION sep 21, 2004 17:33:33.633
eclipse.buildId=unknown
java.version=1.5.0-beta2
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_ES
Command-line arguments: -application org.eclipse.ui.ide.workbench
!ENTRY org.eclipse.osgi sep 21, 2004 17:33:33.633
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench"
could not be found in the registry. The applications available are: <NONE>.
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:325)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
!ENTRY org.eclipse.osgi sep 21, 2004 17:33:33.643
!MESSAGE Bundle initial@reference:file:C:/Documents and Settings/Jose/Mis
documentos/PROFESIONAL/PROYECTO
GRANADA/eclipse/plugins/org.eclipse.ui.ide_3.0.0/ [10] was not resolved.
!SUBENTRY 1 org.eclipse.osgi sep 21, 2004 17:33:33.643
!MESSAGE Missing required bundle org.eclipse.core.resources_0.0.0.
org.eclipse.core.runtime.compatibility_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.views_0.0.0.
!MESSAGE Missing required bundle org.eclipse.update.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.update.ui_0.0.0.
WHAT CAN I DO?
Thank you very much
Marion Schmid wrote:
> Hi Jose,
> assuming that you already have the examples in your features/plugins folder
> of your installation, create a simple project folder and then
> File > new > Example... > GEF > Flow/Logic Diagram
> Select your folder as parent > finish
Re: How to run GEF examples [message #151585 is a reply to message #151577] |
Tue, 21 September 2004 12:01  |
http://help.eclipse.org/help30/index.jsp?topic=/org.eclipse. pde.doc.user/guide/pde_running.htm
This is PDE-related, so try the eclipse.platform newsgroup for more help.
"Jose" <jdelgad@fedro.ugr.es> wrote in message
news:ciphib$ul4$1@eclipse.org...
> Hi again!
> !STACK 1
<NONE>.
> at
java:325)
> at
> at
> WHAT CAN I DO?
> Thank you very much
> > Hi Jose,
folder
FUDForum. Page generated in 0.07965 seconds
