Home » Archived » BIRT » Palette Tab not showing
Palette Tab not showing [message #151508] Thu, 06 April 2006 11:18 Go to next message
I've installed birt and started the tutorial. I noticed that I don't have
the palette tab and can't find where to turn it on. Did I miss something
during the install? Any help would be appreciated.
Re: Palette Tab not showing [message #151528 is a reply to message #151508] Thu, 06 April 2006 11:53 Go to previous messageGo to next message
Barry,
Look at the window->show view->other->basic->palette.
If you just installed it should be there by default. What version did you
install?
Jason
"Barry" <barry_wells@ca4.uscourts.gov> wrote in message
news:19738f0fdbd5239e4c893ef381babca5$1@www.eclipse.org...
Re: Palette Tab not showing [message #151552 is a reply to message #151508] Thu, 06 April 2006 11:59 Go to previous messageGo to next message
Barry,
Are you using the BIRT_ALL_IN_ONE?
If you Windows -> Open Perspective -> Other do you see Business
Intelligence and Reporting Tools (BIRT) as an option?
What version of Eclipse are you using ?
Often this type of problem is related to not having the appropriate
versions GEF and EMF (see the download page)
Scott Rosenbaum
BIRT PMC
> have the palette tab and can't find where to turn it on. Did I miss
> something during the install? Any help would be appreciated.
Re: Palette Tab not showing [message #151586 is a reply to message #151528] Thu, 06 April 2006 12:31 Go to previous message
I found the palette. It's on the far right as a fly-out panel.
Previous Topic:Passing group of rowdata to a query
Next Topic:How to run the chart examples
Current Time: Sun Jun 08 13:09:37 EDT 2025
Powered by FUDForum. Page generated in 0.03249 seconds
