Home » Modeling » GMF (Graphical Modeling Framework) » how do we use EIDAttribute ?
how do we use EIDAttribute ? [message #151369] Mon, 17 September 2007 10:11 Go to next message
Originally posted by: NOSPAM.xyz.com
Hi there,
I have to move Nodes between different diagram editors
and to me it seems a good idea to use their string IDs to track where they
are.
However I just noticed that
EClass eClass = eObject.eClass();
EAttribute eIDAttribute = eClass.getEIDAttribute();
returns null from my Nodes, so I can not use
eObject.eSet(eIDAttribute,
createFromString(eIDAttribute.getEAttributeType(), id));
On the other hand, the diagram XMLResource has an entry for my nodes in its
getIDToEObjectMap()
and the nodes are persisted with these IDs in XML.
Is there a way to set these IDs at run time, or I am missing them from the
very beginning in my model.
The usage pattern of EIDAttribute is way not clear to me. Any refs?
Theo
Re: how do we use EIDAttribute ? [message #151377 is a reply to message #151369] Mon, 17 September 2007 10:16 Go to previous messageGo to next message
--------------090104050700050807080109
Theo,
Maybe reading some of the previous posts on the subject will answer your
questions:
http://www.eclipse.org/search/search.cgi?q=extrinsic+intrins ic+ID&cmd=Search%21&form=extended&wf=574a74& ps=10&m=all&t=5&ul=%2Fnewslists%2Fnews.eclipse.t ools.emf&wm=wrd&t=News&t=Mail
< http://www.eclipse.org/search/search.cgi?q=extrinsic+intrins ic+ID&cmd=Search%21&form=extended&wf=574a74& ps=10&m=all&t=5&ul=%2Fnewslists%2Fnews.eclipse.t ools.emf&wm=wrd&t=News&t=Mail>
Theo wrote:
> Hi there,
> are.
> getIDToEObjectMap()
> Thanks
> Theo
<html>
<head>
</head>
Theo,<br>
<br>
your questions:<br>
<blockquote><a
href=" http://www.eclipse.org/search/search.cgi?q=extrinsic+intrins ic+ID&amp ;cmd=Search%21&amp;form=extended&amp;wf=574a74&a mp;ps=10&amp;m=all&amp;t=5&amp;ul=%2Fnewslists%2 Fnews.eclipse.tools.emf&amp;wm=wrd&amp;t=News&am p;t=Mail "> http://www.eclipse.org/search/search.cgi?q=extrinsic+intrins ic+ID&amp ;cmd=Search%21&amp;form=extended&amp;wf=574a74&a mp;ps=10&amp;m=all&amp;t=5&amp;ul=%2Fnewslists%2 Fnews.eclipse.tools.emf&amp;wm=wrd&amp;t=News&am p;t=Mail </a><br>
</blockquote>
<br>
Theo wrote:
<blockquote cite="mid:fcm1uc$utd$1@build.eclipse.org" type="cite">
<pre wrap="">Hi there,
are.
getIDToEObjectMap()
Theo
</pre>
</blockquote>
<br>
</body>
</html>
--------------090104050700050807080109--
Re: how do we use EIDAttribute ? [message #151386 is a reply to message #151369] Mon, 17 September 2007 10:18 Go to previous messageGo to next message
Hi, Theo,
This is really an EMF question (hence my reply to that group).
The XMLResource can maintain a mapping of extrinsic object IDs. The
eIDAttribute is used to implement intrinsic object IDs. If your EClass has
an EAttribute (usually of type EString, I imagine) that has its isID
property set to true, then this is what the EClass returns as its
eIDAttribute. Evidently, you didn't define an ID attribute in your model.
To assign an object's extrinsic ID, you can use the
XMLResource::setID(EObject, String) method. Otherwise, the resource will
automatically compute an ID any way that it can if it is configured (as
GMFResources are) to use IDs.
Note, also, that the XMLResource implementation remembers the ID of an
object that has been detached, in case it should become re-attached to the
same or another resource. This ensures that your object will still have
the same ID when it is detached from one resource in the one diagram editor
and attached to the other resource in the other editor.
HTH,
Christian
Theo wrote:
> Hi there,
> are.
> its
> getIDToEObjectMap()
> Thanks
> Theo
Re: how do we use EIDAttribute ? [message #151878 is a reply to message #151369] Thu, 20 September 2007 17:52 Go to previous message
Thank you Ed, Christian,
got it now
"Theo" <NOSPAM@xyz.com> wrote in message
news:fcm1uc$utd$1@build.eclipse.org...
> Hi there,
> are.
> its
> getIDToEObjectMap()
> Thanks
> Theo
Previous Topic:Problems with labels mapped into nodes
Next Topic:Write an audit rule
Current Time: Fri Nov 07 17:12:52 EST 2025
Powered by FUDForum. Page generated in 0.03997 seconds
