| Can't load Schema [message #1153] | Fri, 27 September 2002 15:20  |  |
| Eclipse User  |  |  |  |  | Originally posted by: troynet+web.ugcs.net
 I'm trying the example from Shane Curcuru's article:
 ResourceSet resourceSet = new ResourceSetImpl();
 XSDResourceImpl xsdSchemaResource =               /* line 40 */
 (XSDResourceImpl) resourceSet.getResource(
 URI.createDeviceURI( schemaURL, true));
 and my schemaURL looks like this:
 file:/home/troy/xxml/schema/xxml.xsd
 But I get this error when I run:
 Exception in thread "main" java.lang.RuntimeException: Cannot create a
 resource for ' + uri + '
 org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:271)
 at org.xxml.schema.Schema.<init>(Schema.java:40)
 at org.xxml.schema.SchemaUI.main(SchemaUI.java:112)
 Why would I get this error?
| Re: Can't load Schema [message #1209 is a reply to message #1153] | Fri, 27 September 2002 19:01  |  |
| Eclipse User  |  |  |  |  | Originally posted by: merks.ca.ibm.com
 --------------E5DBCA926C9F9D2CE489D2E8
 Content-Type: text/plain; charset=us-ascii
 Troy,
 When running within Eclipse, the plugin environment does initialization that must be done
 manually if you are running stand-alone.
 http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String)
 In particular, you need to register a resouce factory to handle .xsd files.  It can be done
 in the global registry in this way:
 Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd", new
 XSDResourceFactoryImpl());
 Within Eclipse, this is done by the plugin.xml registration.
 >         at
 Ed Merks
 Content-Type: text/html; charset=us-ascii
 <!doctype html public "-//w3c//dtd html 4.0 transitional//en">
 <html>
 Troy,
 <p>When running within Eclipse, the plugin environment does initialization
 that must be done manually if you are running stand-alone.
 <p> <a href=" http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String)"> http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String)</a>
 <p>In particular, you need to register a resouce factory to handle .xsd
 files.  It can be done in the global registry in this way:
 <blockquote> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
 new XSDResourceFactoryImpl());</blockquote>
 <br>
 <p>Troy Bridoux wrote:
 <blockquote TYPE=CITE>I'm trying the example from Shane Curcuru's article:
 <p>ResourceSet resourceSet = new ResourceSetImpl();
 <br>XSDResourceImpl xsdSchemaResource  =       ;       ;
 /* line 40 */
 <br>  (XSDResourceImpl) resourceSet.getResource(
 <br>     URI.createDeviceURI( schemaURL, true));
 <p>and my schemaURL looks like this:
 <br><a href="file:/home/troy/xxml/schema/xxml.xsd">file:/home/troy/xxml/schema/xxml.xsd </a>
 <p>But I get this error when I run:
 <p>Exception in thread "main" java.lang.RuntimeException: Cannot create
 a
 <br>resource for ' + uri + '
 <br>          at
 <br> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:271)
 <br>          at org.xxml.schema.Schema.<init>(Schema.java:40)
 <br>          at org.xxml.schema.SchemaUI.main(SchemaUI.java:112)
 <p>Why would I get this error?</blockquote>
 <p>--
 <br>Ed Merks
 <br> </html>
 --------------E5DBCA926C9F9D2CE489D2E8--
| Re: Can't load Schema [message #562662 is a reply to message #1153] | Fri, 27 September 2002 19:01  |  |
| Eclipse User  |  |  |  |  | --------------E5DBCA926C9F9D2CE489D2E8 Content-Type: text/plain; charset=us-ascii
 Troy,
 >         at
 Ed Merks
 <html>
 Troy,
 <br>
 /* line 40 */
 a
 <br>          at
 <p>--
 <br>Ed Merks
 <br> </html>
FUDForum. Page generated in 0.03846 seconds
