External Tools causing unwanted Build All [message #151292] |
Tue, 16 August 2005 21:26  |
Originally posted by: eclipse.dharty.com
I'm having the same problem as another poster (Eric Mader) that was
never resolved.
Essentially, if you create an External Tool, NOT as a builder, it tries
to call build everytime you use it. In my case, build -all. This is
exactly what I do not want. My External Tools do things like check out
files from my version control, diff files against repository etc.
Is there a way to stop the project from building when I want to run an
external tool?
David
Re: External Tools causing unwanted Build All [message #151300 is a reply to message #151292] |
Tue, 16 August 2005 22:13  |
> never resolved.
> external tool?
> David
I found a solution, kind of.
In Window->Preferences->Run/Debug->Launching
UnSelect "Build if required before launching"
My concern is that this will also cause "Run" or Debug commands to not
build. I can imaging that a lot of people would like to build before
running or debugging, but not before performing other miscelaneous tasks
like grep, diff etc.
FUDForum. Page generated in 0.27327 seconds
