Home » Eclipse Projects » JFace » Issue with EditingSupport#canEdit
Issue with EditingSupport#canEdit [message #14161] Thu, 11 June 2009 04:02 Go to next message
is the celleditor activation per mouse events as showed in
Snippet021CellEditorsOnDoubleClick also feasible using EditingSupport in
place of ICellModifier? Attempting this I've experienced that differently
from ICellModifier(#canModify()) EditingSupport#canEdit() is called always
before the event handler receive the mouse events from table. Is this
issue known?
Thomas
Re: Issue with EditingSupport#canEdit [message #14211 is a reply to message #14161] Fri, 12 June 2009 05:42 Go to previous messageGo to next message
I don't see an issue there.
If you are using the 3.3 API and want to modify the activation behaviour
you'll have create your own TableViewerEditor#create and pass your
custom ColumnViewerEditorActivationStrategy.
Tom
Thomas Paradies schrieb:
> differently from ICellModifier(#canModify()) EditingSupport#canEdit() is
> called always before the event handler receive the mouse events from
> table. Is this issue known?
> Thomas
Re: Issue with EditingSupport#canEdit [message #14228 is a reply to message #14211] Fri, 12 June 2009 08:11 Go to previous message
Tom,
thank you for your comments - yes I'm using the 3.3 API but first I've
expected the same activation behaviour as with the ICellModifier as the
default... ok, thanks to your help I'm wiser now :-)
Thomas
> Tom
>> Thomas
Previous Topic:[Databinding] binding to objects attributes
Next Topic:Setting The Input Data Of IViewPart Subclass
Current Time: Tue Jul 15 14:35:31 EDT 2025
Powered by FUDForum. Page generated in 0.07174 seconds
