Strange behaviour of GMF 1.0.100.v20070601 [message #151152] |
Mon, 17 September 2007 04:41  |
Originally posted by: michael.dev.NOSPAM.gmx.de
Hello All,
suddenly some changed of gmfgraph were not updated in the diagram. I
usually edit the graph model by using the gmfmap editor and edit the
loaded graph resource.
I usually use the Transform button in the Dashboard to update gmfgen.
The file is not being updated anymore. Clicking on Transform does not
show any error. I changed some properties in the genmodel like "List
View" of Compartments (nothing that should disturb the process).
I tried to rebuild gmfgen deleting it and right clicking on gmfap and
using "Create generator model...". The wizard did not open. After a
start with "eclipse -clean" it worked again. In the wizard it displayed
that something is wrong in the mapping. No further information. Nothing
in the Problems view, nothing in .log-File. By deleting some nodes of
the mapping (which did not change btw!) the wizard was happy. Suddenly
the mapping file was marked with an error sign in the package explorer
and it displayed 2 errors in the Problems view:
- 'Containment Feature' must reference the same class or super type of
'Domain Meta Element' of the referenced node
- The required feature 'ownedChild' of Top Node Reference <metaInfo>'
must be set
Now for a try I deleted all mappings inside the mapping file and the
problems are still displayed. It's very annoying to delete .gmfgen and
even .gmfmap
Anyone of you had strange behaviour like this, too?
Michael
FUDForum. Page generated in 0.07758 seconds
