Home » Archived » BIRT » how to format date values in charts
how to format date values in charts [message #151121] Wed, 05 April 2006 10:35 Go to next message
Originally posted by: stefano.comarin.primeur.com
I would like to format the date value on the X axis of charts according
to the user locale. Is it possible to do this at runtime with Javascript?
Stefano
Re: how to format date values in charts [message #151217 is a reply to message #151121] Wed, 05 April 2006 15:43 Go to previous messageGo to next message
Doesn't the format specifier allow you to do that already? If you click on
format button for the x axis labels, you can specify a date format (given
the axis is set as date type). I believe it should adjust at runtime
depending on the locale.
David
"Stefano Comarin" <stefano.comarin@primeur.com> wrote in message
news:e10kiq$fab$1@utils.eclipse.org...
> I would like to format the date value on the X axis of charts according to
> Stefano
Re: how to format date values in charts [message #151410 is a reply to message #151217] Thu, 06 April 2006 08:13 Go to previous messageGo to next message
The axis is set as date type but it does not adjust on the locale.
I tried to change the locale but the date format in charts is always the
same (US English). Is this maybe a bug?
Stefano
> David
>>Hi,
>>Thanks,
>>Stefano
Re: how to format date values in charts [message #151417 is a reply to message #151410] Thu, 06 April 2006 08:24 Go to previous messageGo to next message
Did you format the date with the format UI?
David
news:e130lo$2j5$1@utils.eclipse.org...
> Stefano
>> on format button for the x axis labels, you can specify a date format
>> (given the axis is set as date type). I believe it should adjust at
>> runtime depending on the locale.
>> Thanks,
>> David
>>>Hi,
>>>Thanks,
>>>Stefano
Re: how to format date values in charts [message #151514 is a reply to message #151417] Thu, 06 April 2006 11:24 Go to previous messageGo to next message
I use the Format Specified Editor in the Chart Editor. I set the X axis
type to DateTime, format = Standard, Type = Short, Details = DateTime.
Stefano
> David
>>Thanks,
>>Stefano
>>>Thanks,
>>>David
>>>>Hi,
>>>>Thanks,
>>>>Stefano
Re: how to format date values in charts [message #151822 is a reply to message #151514] Fri, 07 April 2006 04:32 Go to previous message
Please file a bugzilla entry in that case.
David
news:e13bql$kqe$1@utils.eclipse.org...
> Stefano
>> Thanks,
>> David
>>>Thanks,
>>>Stefano
>>>>Thanks,
>>>>David
>>>>>Hi,
>>>>>Javascript?
>>>>>Thanks,
>>>>>Stefano
Previous Topic:Change a database connection or pass a dataset in a parameter
Next Topic:Urgent :Chart Image Size Problem
Current Time: Sat Jul 26 12:41:32 EDT 2025
Powered by FUDForum. Page generated in 0.06040 seconds
