libswt-pi-gtk-3064.so: undefined symbol: XTestFakeButtonEvent [message #151051] |
Sun, 07 May 2006 03:29  |
Originally posted by: garylshaw.hotmail.com
Not sure if this has been asked before and if so could you point me to
the post.
Thank you
Info
Linux redbsd.com 2.6.9-34.EL #1 Fri Feb 24 16:44:51 EST 2006 i686 i686
i386 GNU/Linux
rpm -qa |grep eclipse
eclipse-ecj-3.0.2-8
eclipse-platform-3.0.2-8
eclipse-platform-devel-3.0.2-8
with
j2re-1.4.2-11.2.el4.rf
!SESSION May 06, 2006 21:34:57.918
eclipse.buildId=200503110845
java.version=1.4.2_06
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
!ENTRY org.eclipse.osgi May 06, 2006 21:34:57.919
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: /usr/lib/eclipse/libswt-pi-gtk-3064.so:
/usr/lib
/eclipse/libswt-pi-gtk-3064.so: undefined symbol: XTestFakeButtonEvent
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.gtk.OS.<clinit>(OS.java:19)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 63)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:118)
org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:268)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:153)
org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Applicati
on.java:122)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:72
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformAct
ivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.ja
va:273)
va:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
ldd /usr/share/eclipse/eclipse
libgtk-x11-2.0.so.0 => /usr/lib/libgtk-x11-2.0.so.0 (0x06a00000)
libgdk_pixbuf-2.0.so.0 => /usr/lib/libgdk_pixbuf-2.0.so.0
(0x00810000)
libc.so.6 => /lib/tls/libc.so.6 (0x00a08000)
libgdk-x11-2.0.so.0 => /usr/lib/libgdk-x11-2.0.so.0 (0x0651b000)
libgobject-2.0.so.0 => /usr/lib/libgobject-2.0.so.0 (0x0058d000)
libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x00b5e000)
libpangoxft-1.0.so.0 => /usr/lib/libpangoxft-1.0.so.0 (0x00834000)
libpangox-1.0.so.0 => /usr/lib/libpangox-1.0.so.0 (0x00827000)
libpango-1.0.so.0 => /usr/lib/libpango-1.0.so.0 (0x00c80000)
libatk-1.0.so.0 => /usr/lib/libatk-1.0.so.0 (0x0083b000)
libgmodule-2.0.so.0 => /usr/lib/libgmodule-2.0.so.0 (0x005cb000)
libdl.so.2 => /lib/libdl.so.2 (0x00b33000)
libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0x00793000)
libm.so.6 => /lib/tls/libm.so.6 (0x00b39000)
/lib/ld-linux.so.2 (0x009ef000)
libXrandr.so.2 => /usr/X11R6/lib/libXrandr.so.2 (0x009ba000)
libXi.so.6 => /usr/X11R6/lib/libXi.so.6 (0x06639000)
libXinerama.so.1 => /usr/X11R6/lib/libXinerama.so.1 (0x00466000)
libXft.so.2 => /usr/X11R6/lib/libXft.so.2 (0x001cb000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x00137000)
libfontconfig.so.1 => /usr/lib/libfontconfig.so.1 (0x001a3000)
libXcursor.so.1 => /usr/X11R6/lib/libXcursor.so.1 (0x005d1000)
libXrender.so.1 => /usr/X11R6/lib/libXrender.so.1 (0x003a8000)
libXext.so.6 => /usr/X11R6/lib/libXext.so.6 (0x00c27000)
libpangoft2-1.0.so.0 => /usr/lib/libpangoft2-1.0.so.0 (0x00857000)
libexpat.so.0 => /usr/lib/libexpat.so.0 (0x00431000)
libz.so.1 => /usr/lib/libz.so.1 (0x00275000)
Re: Redhat [message #151059 is a reply to message #151055] |
Sun, 07 May 2006 11:24  |
Originally posted by: myersj.gmail.com
I'd suggest trying Eclipse downloaded from http://www.eclipse.org/
The eclipse rpms that you have installed are probably meant to run with
the GCJ runtime installed with RedHat. If you are able to run Eclipse
from eclipse.org, but not the ones included with RedHat, please open a
bug with RedHat.
Hope this helps,
- Jeff
FUDForum. Page generated in 0.33954 seconds
