turn or automatic project build ? [message #150803] |
Fri, 26 March 2004 16:50  |
Originally posted by: jalpesh.bea.com
I was recently on an IDEA newsgroup and somebody mentioned that eclipse
3.0 builds also have a feature by which you can turn of automatic
build of your project in eclipse.
Does anyone know how to do that ? My project has over 5000 files and
rebuilding the project takes forever for me as I'm changing the files.
It would be great if I can turn of auto-build (just like IDEA does)
Also would anyone know what do we lose by turning of the automatic
project build action.
Jalpesh.
Re: turn or automatic project build ? [message #151515 is a reply to message #151132] |
Tue, 30 March 2004 03:35  |
Originally posted by: frode.halvorsen.hoco.no
I also have trouble with things like this in projects with many files, but
it is not a rebuild that takes place. It is the update of the workspace,
especially the task/error list if there is many warnings or unfinished
todo's etc.
It seems that the workplace searches through every file in order to get new
status for this.
"Eric Rizzo" <eclipse@rizzoweb.com> skrev i melding
news:c44e1e$pvu$1@eclipse.org...
> You say that is takes "forever" to build your whole project. That may be
> the case, but the automatic builds that happen whenever you save a
> source file are not doing a complete build. The Eclipse compiler is what
> is called an incremental compiler, meaning it only compiles what was
> changed and whatever depends on what was changed. So when you change a
> single file, it will be re-compiled and so will whatever other classes
> depend on it, but certainly not your entire project. Even in large
> projects, this takes AT MOST a couple of seconds, IME.
> What I'm trying to tell you is that it is rarely beneficial to disable
> the automatic incremental compilation - it is very intelligent about
> what to compile and what not to. If you are seeing complete rebuilds of
> your project all the time then something is wrong - that is not normal
> behavior.
> HTH,
> Eric
> There are no rules here - we're trying to accomplish something.
> - Thomas Edison
FUDForum. Page generated in 0.24436 seconds
