Home » Eclipse Projects » Remote Application Platform (RAP) » Java2Script - the SWT to JS.
Java2Script - the SWT to JS. [message #1149] Mon, 06 November 2006 05:30 Go to next message
Just in case you don't know about this project. They compile SWT code to
Java Script application, a GWT does. Maybe you could use it?
http://j2s.sourceforge.net/
Marcin Okraszewski
Re: Java2Script - the SWT to JS. [message #1175 is a reply to message #1149] Thu, 09 November 2006 15:42 Go to previous messageGo to next message
Originally posted by: jkrause.innoopract.com
Hi Marcin,
Thanks for the pointer. We are aware of that project, but as you stated
it is closer to GWT then to our approach. RAP is more server centric,
and can thus go beyond the widget toolkit to osgi, plugins and a
workbench. This will be quite difficult to achieve in JavaScript.
There is actually a new demo available, based on our research for
creating a widget toolkit close to the SWT api.
http://rap.eclipse.org:3001/rwt/
More info on this will follow.
Jochen
Marcin Okraszewski wrote:
> Best regards,
> Marcin Okraszewski
Re: Java2Script - the SWT to JS. [message #1202 is a reply to message #1175] Sat, 11 November 2006 10:19 Go to previous messageGo to next message
the demo has moved to:
http://rap.eclipse.org/rwt/
However, this is a virtual server with sometimes really bad response
times (not the fault of rwt). We will try to get a dedicated server, in
the meantime the same demo is also on http://rap.innoopract.com/rwt/
Jochen
Jochen Krause wrote:
> Hi Marcin,
> Jochen
>> to Java Script application, a GWT does. Maybe you could use it?
>> Best regards,
>> Marcin Okraszewski
Demo moved [message #3391 is a reply to message #1202] Mon, 29 January 2007 06:57 Go to previous message
RWT widget toolkit demo:
http://rap.eclipse.org/rap?w4t_startup=controls
Workbench demo:
> Jochen
>> Hi Marcin,
>> stated it is closer to GWT then to our approach. RAP is more server
>> centric, and can thus go beyond the widget toolkit to osgi, plugins
>> and a workbench. This will be quite difficult to achieve in JavaScript.
>> Jochen
>>> Hi,
>>> Best regards,
>>> Marcin Okraszewski
Previous Topic:Is RAP specifically for Eclipse RCP? Can RAP be used/run in Eclipse IDE/workbench/workspace environ
Next Topic:Technical overview for new widget toolkit (RWT) and demo available
Current Time: Wed Jul 16 23:56:40 EDT 2025
Powered by FUDForum. Page generated in 0.29355 seconds
