Home » Language IDEs » PHP Development Tools (PDT) » Autocomplete type hinting
Autocomplete type hinting [message #14112] Mon, 16 April 2007 17:08 Go to next message
I've been using PDT/Xdebug for a while and I find it really good.
One thing I'm not geting, though - I have some method returning an object -
on the new var I don't get autocomplete, because it doesn't know its type. I
tried hinting it using phpdoc, but it doesn't seem to work.
Any help would be appreciated.
Emil Ivanov
Re: Autocomplete type hinting [message #14131 is a reply to message #14112] Mon, 16 April 2007 17:12 Go to previous messageGo to next message
Many appologies - I just managed to figure it out myself.
The sollution is to add the pphpdoc AFTER the variable. I was used to
PHPed's convention, which requires me to add it before the var.
I'm sorry, again, for the flood.
Take care and keep up the good work!
"Emil Ivanov" <emil.vladev@gmail.com> wrote in message
news:f00ojf$efv$1@build.eclipse.org...
> object - on the new var I don't get autocomplete, because it doesn't know
> its type. I tried hinting it using phpdoc, but it doesn't seem to work.
> Emil Ivanov
Re: Autocomplete type hinting [message #14148 is a reply to message #14131] Mon, 16 April 2007 20:10 Go to previous messageGo to next message
Originally posted by: apaz.yahoo.com
I wouldn't think that's a user error. documentation typically goes
before the variable declaration. I would log it at least as an
enhancement (if not a bug).
-a.
>> Regards,
>> Emil Ivanov
Re: Autocomplete type hinting [message #14200 is a reply to message #14148] Tue, 17 April 2007 05:55 Go to previous messageGo to next message
Logged as an echantment request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=182693
"Andres Paz" <apaz@yahoo.com> wrote in message
news:4624105F.6050008@yahoo.com...
>I wouldn't think that's a user error. documentation typically goes before
>the variable declaration. I would log it at least as an enhancement (if not
>a bug).
> -a.
>>> Hi,
>>> know its type. I tried hinting it using phpdoc, but it doesn't seem to
>>> work.
>>> Regards,
>>> Emil Ivanov
Re: Autocomplete type hinting [message #14234 is a reply to message #14200] Tue, 17 April 2007 10:37 Go to previous messageGo to next message
I think this is a bug. You should therefore not list this as an enhancement
request. Once this bug is fixed, you need to change all your variable
documentation. In addition, php documentation tools won't process comments
below variables. This is critical, if not blocker!
"Emil Ivanov" <emil.vladev@gmail.com> schreef in bericht
news:f025ib$kdq$1@build.eclipse.org...
>>not a bug).
>> -a.
>>>> Hi,
>>>> work.
>>>> Regards,
>>>> Emil Ivanov
Re: Autocomplete type hinting [message #14249 is a reply to message #14234] Tue, 17 April 2007 12:01 Go to previous messageGo to next message
I dont't think of it as a Bug.
> below variables.
It's not a bug, since these Code-Hints are not PHPDocs.
The correct syntax (as stated in PDT's help) is:
/* @var $Foo MyFoo */
This ist just a comment, not a PHPDoc.
You can use /**, but that's just optional and in respect to a
documentation tool plain wrong, IMHO.
I can't think of a documentation tool, that would make good use of such
a PHPDoc regardless of it's position compared to the hinted variable.
Since these variables are not in any structured position within the
code, but somewhere a documentation tool wouldn't expect a PHPDoc anyway.
>>> not a bug).
>>> -a.
>>>>> Hi,
>>>>> work.
>>>>> Regards,
>>>>> Emil Ivanov
Re: Autocomplete type hinting [message #15101 is a reply to message #14131] Wed, 18 April 2007 03:24 Go to previous messageGo to next message
Hello Emil,
As I understand you are trying to hint a variable's type.
Why not trying to hint the function's return type through PHPDoc? Like that:
* Short description
* @return companyClass
function createCompany() {
return new companyClass();
Using this:
$company = createCompany();
I get a perfectly working code completion for companyClass' methods.
Of course companyClass' definition must be within the same project or
within the project or folder in "PHP Include Path" defined in Eclipse PDT.
Piotr Szczepanik
Re: Autocomplete type hinting [message #15125 is a reply to message #15101] Wed, 18 April 2007 05:39 Go to previous messageGo to next message
> Hello Emil,
> that:
> * Short description
> Using this:
Hi Piotr,
you are perfectly correct. This is a) working for TypeHinting and b)
correctly parsable PHPDoc
But look at this construct (derived from yours):
* Short description
return array(new companyClass(), new companyClass(), ...);
Using this:
$companies = createCompany();
foreach ($companies as $company)
/* @var $company companyClass */
$company->
Here you would have no TypeHinting, if you leave out the /* @var.
You need to add this Comment after the definition of $company.
If you would add it before the definition, PDT would use some logic to
determine the Type of the variable and override your comment.
> Best regards,
> Piotr Szczepanik
Re: Autocomplete type hinting [message #15134 is a reply to message #15125] Wed, 18 April 2007 08:12 Go to previous messageGo to next message
> * Short description
Hi Christian,
writing my message I was assuming (as implied by Emil's first post) that
the function is returning an object. That's why I suggested documenting
the function itself.
> Using this:
> $company->
That is also perfectly correct ;)
Strange. In my test case autocomplete is working perfectly even if I put
the type hinting above the variable's first use.
foreach ($companies as $companyXXX) {
/* @var $companyXXX companyClass */
$companyXXX->
Eclipse 3.2.2, PDT 0.7RC3, Java 1.5 (Linux and Windows).
Maybe it's caused by variable's name reuse for different purposes?
I don't know.
Piotr Szczepanik
Re: Autocomplete type hinting [message #15191 is a reply to message #15134] Wed, 18 April 2007 09:27 Go to previous messageGo to next message
Nono, everything's fine.
You just mixed 'first use' with 'definition'
In our example the Definition is
and the comment follows ^^
> $companyXXX->
> I don't know.
> Best regards,
> Piotr Szczepanik
Re: Autocomplete type hinting [message #15255 is a reply to message #14249] Wed, 18 April 2007 09:34 Go to previous messageGo to next message
Yes,
I got your point.
Now I left this as an enchantment to colorize the comment
/* @var $db PDO */
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=182693)
Thank you all for the replies.
Take care,
Emil Ivanov
Re: Autocomplete type hinting [message #15448 is a reply to message #15191] Wed, 18 April 2007 14:22 Go to previous message
No. I was meaning the 'first use' in that sentence. Above the
$companyXXX->....
That's right ;)
But in my opinion it actually does not matter where you put it.
I use some templates in my application and (for convenience) put the
typehinting for variables which results from foreach loops at the top of
my template file and it also works perfectly well.
Like that:
<?php
/* @var $project projectClass */
<div>
<?php foreach ($companies as $company): ?>
<div><?php echo $company->| Here I have autocomplete for
companyClass instance ?></div>
<?php endforeach; ?>
</div>
The markup is just example.
I've just checked that and it works.
Piotr
Previous Topic:Help - Project Navigator
Next Topic:debuging from mozilla with zend eclipse plugin
Current Time: Sun Jul 13 11:28:01 EDT 2025
Powered by FUDForum. Page generated in 0.19022 seconds
