Re: Java2Script - the SWT to JS. [message #1202 is a reply to message #1175] |
Sat, 11 November 2006 10:19   |
Originally posted by: jkrause.innoopract.com
the demo has moved to:
http://rap.eclipse.org/rwt/
However, this is a virtual server with sometimes really bad response
times (not the fault of rwt). We will try to get a dedicated server, in
the meantime the same demo is also on http://rap.innoopract.com/rwt/
Jochen
Jochen Krause wrote:
> Hi Marcin,
> Thanks for the pointer. We are aware of that project, but as you stated
> it is closer to GWT then to our approach. RAP is more server centric,
> and can thus go beyond the widget toolkit to osgi, plugins and a
> workbench. This will be quite difficult to achieve in JavaScript.
> There is actually a new demo available, based on our research for
> creating a widget toolkit close to the SWT api.
> http://rap.eclipse.org:3001/rwt/
> More info on this will follow.
> Jochen
> Marcin Okraszewski wrote:
>> Just in case you don't know about this project. They compile SWT code
>> to Java Script application, a GWT does. Maybe you could use it?
>> http://j2s.sourceforge.net/
>> Best regards,
>> Marcin Okraszewski
Demo moved [message #3391 is a reply to message #1202] |
Mon, 29 January 2007 06:57  |
RWT widget toolkit demo:
http://rap.eclipse.org/rap?w4t_startup=controls
Workbench demo:
> Jochen
>> Hi Marcin,
>> stated it is closer to GWT then to our approach. RAP is more server
>> centric, and can thus go beyond the widget toolkit to osgi, plugins
>> and a workbench. This will be quite difficult to achieve in JavaScript.
>> Jochen
>>> Hi,
>>> Best regards,
>>> Marcin Okraszewski
FUDForum. Page generated in 0.13023 seconds
