Home » Eclipse Projects » GEF » Connection clipping current state of the art
Connection clipping current state of the art [message #150418] |
Fri, 10 September 2004 02:32 |
Originally posted by: vladimir.bogus.com
What is the preferred way of dealing with the default absense of the
connection's clipping behaviour (The connection node clipping does not
affect the clipping of the connection itself, and, for example, if the nodes
are clipped off and are not visible, the connection will still be visible).
One suggestion was to set the connection's parent to the nodes' container
Figure. This indeed adds clipping to the connection (with a seemingly minor
side effect of NullPointerException thrown at
org.eclipse.gef.editpolicies.BendpointEditPolicy.createHandl esForUserBendpoi
nts(BendpointEditPolicy.java:75 on selecting a connection. What is the
preferred way of dealing with this exception?).
I did not find any standard and general solutions to a more general problem
of the connections' nodes belonging to different containers and so any
suggestions would be appreciated in this regard.
Vladimir
Re: Connection clipping current state of the art [message #150658 is a reply to message #150583] |
Mon, 13 September 2004 00:28 |
Originally posted by: vgusev.graphlogic.com
This seems to be the beginning of dealing with this issue and has side
effects listed in the original post. As a general solution, I am think about
implementing a special connection layer in the Figure that is the
bottom-most on the ancestor chain? When the user draws the connection it
paints on the standard connection layer so it is not clipped at all. After
the user finishes drawing the connection, it is moved to this special layer
belonging to the bottom-most ancestor of the connected nodes, which should
allow proper clipping. What do you think of this solution design-wise and in
terms of possible side effects? Thanks.
Vladimir
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:chvglr$hos$1@eclipse.org...
> From one of Randy Hudson's previous posts:
> If you want to change the figure which parents the
> connection to be some layer in your container, see
> AbstractConnectionEditPart#activateFigure(). This determines the
> connection's parent, and therefore its clipping.
> "Vladimir" <vladimir@bogus.com> wrote in message
> news:chr3h2$ncc$1@eclipse.org...
> > Hello,
> nodes
> visible).
container
> minor
> problem
> > Vladimir
Re: Connection clipping current state of the art [message #150735 is a reply to message #150658] |
Mon, 13 September 2004 18:07 |
You could implement the "common ancestor" clipping at the connection router.
Perform the actual clipping on the pointlist itself. This also ensures that
clipping only happens once and at exaclty the right time. Also, hit-testing
will work properly because there is no magic.
I didn't understand the proposed solution below. Feel free to elaborate
"Bob" <vgusev@graphlogic.com> wrote in message
news:ci2oi3$rmi$1@eclipse.org...
about
layer
in
> Vladimir
> > > Hello,
> > nodes
> > visible).
> container
> > minor
> > problem
> > > Vladimir
Re: Connection clipping current state of the art [message #150748 is a reply to message #150735] |
Mon, 13 September 2004 20:56 |
I am proposing to break this use case into two consecutive steps:
1. User selected a node with the connection tool and drags it towards a
second node. In this state, there should be no clipping. To achieve this,
the connection should be drawn on the standard connection layer - no
different compared to how this currently works in gef, and cannot be done
differently since the second node is not known at this point.
2. After the user finished creating connection, in general case, the
connection will have to be clipped. The clipping is dependent upon all of
the successors of the common ancestor. I think that if the connection is
drawn in the layer associated with the common ancestor, the correct clipping
will happen automatically. To achieve this I am proposing to create a new
connection layer in the common ancestor and move the connection created on
step 1 to this new connection layer.
Is step 2 above equivalent to what you call "implementing common ancestor"?
I cannot say, since I don't understand how to do "clipping at the connection
router". Please provide more details. Also, shouldn't this behaviour be the
one of the gef?
Thanks.
Vladimir
"Randy Hudson" <none@us.ibm.com> wrote in message
news:ci4ndg$2js$1@eclipse.org...
router.
that
hit-testing
> about
After
> layer
should
and
> in
> > Vladimir
> > > > Hello,
not
the
> > > nodes
> > > visible).
> > container
seemingly
> > > minor
the
> > > problem
any
> > > > Vladimir
Re: Connection clipping current state of the art [message #150839 is a reply to message #150748] |
Tue, 14 September 2004 18:47 |
news:ci519p$l42$1@eclipse.org...
clipping
ancestor"?
connection
Take a PointList and a Rectangle. Trim the beginning and end of the
pointlist until it lies within the rectangle, which may involve removing
points or modifying points.
the
> one of the gef?
Nope :-) At least half of the GEF applications do not even have nestable
containers. They are just icons and lines.
Re: Connection clipping current state of the art [message #150859 is a reply to message #150839] |
Tue, 14 September 2004 21:40 |
What do you think about switching connection layers?
Thanks.
Vladimir
news:ci7e4a$ima$1@eclipse.org...
this,
done
of
> clipping
new
on
> ancestor"?
> connection
> the
> > one of the gef?
Current Time: Fri Apr 26 16:13:54 GMT 2024
Powered by FUDForum. Page generated in 0.04146 seconds
