Example for custom DataSourceWizard? [message #150399] |
Mon, 03 April 2006 13:45  |
I'm trying to create a Custom DataSource, using an Custom DS Wizard. As
described here
htp://help.eclipse.org/help31/topic/org.eclipse.birt.doc/ref /ext/org_eclipse_birt_report_designer_ui_datasource.html
I added a extension Point org.eclipse.birt.report.designer.ui.odadatasource
to my plugin.xml, which extends the
org.eclipse.datatools.connectivity.oda.design.ui.wizards.New DataSourceWizard-class.
My new DS appears in the Report-Designer an my class is aso instantiated
when I press the "next" button, but nothing happens. Which methods do I have
to override, to get a Custom Page as the following?
I've overwritten
public void addCustomPages() {
addPage(new FolderSelectionWizardPage("Testpage1"));
Is there any sample, that helps me getting my effort working?
Am I on the wrong way and should I use an other extension point?
Wolfgang
Re: Example for custom DataSourceWizard? [message #150564 is a reply to message #150399] |
Tue, 04 April 2006 05:29   |
In the flatfile.ui PlugIn, there is a FlatFileDataSourceConnectionWizard
class defined, but I can't find this class anywhere nether in the birt
project nor in the dtp, is this just a dummy?
<extension
point="org.eclipse.birt.report.designer.ui.odadatasource">
<odaDataSourceUI id="org.eclipse.datatools.connectivity.oda.flatfile">
<newDataSourceWizard
class=" org.eclipse.birt.report.data.oda.flatfile.ui.wizards.FlatFil eDataSourceConnectionWizard "/>
<dataSourceEditorPage
class=" org.eclipse.birt.report.data.oda.flatfile.ui.wizards.FolderS electionPage "
displayName="%datasource.selectfolder"
name="selectFolder"
path="/"/>
</odaDataSourceUI>
It seems that this file is not checked in to the cvs!
"Wolfgang Herr" <herr@tambas.at> schrieb im Newsbeitrag
news:e0rmvf$t9e$1@utils.eclipse.org...
> described here
> org.eclipse.birt.report.designer.ui.odadatasource to my plugin.xml, which
> extends the
> have to override, to get a Custom Page as the following?
> I've overwritten
> Thanks
> Wolfgang
Re: Example for custom DataSourceWizard? [message #150783 is a reply to message #150564] |
Tue, 04 April 2006 17:12   |
What version of birt are you using?
If you are using 2.0.0 or 2.0.1 you should find this in CVS under the
source for the flatfile.ui plugin.
Jason
"Wolfgang Herr" <herr@tambas.at> wrote in message
news:e0te96$g6i$1@utils.eclipse.org...
> <extension
> <odaDataSourceUI
> name="selectFolder"
> path="/"/>
> </odaDataSourceUI>
>> described here
>> extends the
>> I've overwritten
>> Thanks
>> Wolfgang
Re: Example for custom DataSourceWizard? [message #150811 is a reply to message #150783] |
Wed, 05 April 2006 02:41   |
I've checked out the source form the head, seems to be the 2.1.0M5 Version
"Jason Weathersby" <jweathersby@actuate.com> schrieb im Newsbeitrag
news:e0unfp$fji$1@utils.eclipse.org...
> Jason
>> <extension
>> <odaDataSourceUI
>> name="selectFolder"
>> path="/"/>
>> </odaDataSourceUI>
>>> Hi,
>>> described here
>>> which extends the
>>> I've overwritten
>>> Thanks
>>> Wolfgang
Re: Example for custom DataSourceWizard? [message #151146 is a reply to message #150811] |
Wed, 05 April 2006 12:10  |
ODA is changing for the 2.1 release. It will still support the 2.0.1 way of
building the GUI though.
You may want to checkout 2.0.1 or checkout the M5 version.
Jason
news:e0vorj$1bv$1@utils.eclipse.org...
>> Jason
>>> <extension
>>> <odaDataSourceUI
>>> name="selectFolder"
>>> path="/"/>
>>> </odaDataSourceUI>
>>>> Hi,
>>>> described here
>>>> which extends the
>>>> instantiated when I press the "next" button, but nothing happens. Which
>>>> methods do I have to override, to get a Custom Page as the following?
>>>> I've overwritten
>>>> Thanks
>>>> Wolfgang
FUDForum. Page generated in 0.07007 seconds
