Home » Newcomers » Newcomers » java editor source no longer builds
java editor source no longer builds [message #150393] Sun, 30 April 2006 20:52 Go to next message
I set up a project to go over source code in the java editor plugin example.
The plugin itself does run, but apparently its source suffers from eclipse
3.1 upgrade. After making some adjustment for org.eclipse.jface.text, I
still end with one error in JavaEditor.java file.
The type org.eclipse.ui.texteditor.StatusTextEditor cannot be resolved. It
is indirectly referenced from required .class files
Has anyone found a solution to this?
Re: java editor source no longer builds [message #150557 is a reply to message #150393] Tue, 02 May 2006 06:17 Go to previous message
Make sure you use the sample code from 3.1 and import the 3.1 plug-ins.
Dani
Previous Topic:cannot connect to vm when debugging
Next Topic:problem with atl
Current Time: Thu Jul 17 20:17:57 EDT 2025
Powered by FUDForum. Page generated in 0.31506 seconds
