Adding A Default Data Source [message #150319] |
Mon, 03 April 2006 12:26  |
Originally posted by: wyzaj.bethelcollege.edu
In the window that comes right after New Data Source, There is a list of
5 types of sources (example db, flat file, jdbc etc) Is there a way to
add another option to this list. For example I use the same source for
most of my reports but I don't want to copy and paste the source over
and over again in each report, nor do I want to recreate the settings
each time. Or is there a way to make a data source default for the
whole project?
Thanks in advance
Jonathon
Re: Adding A Default Data Source [message #150455 is a reply to message #150319] |
Mon, 03 April 2006 14:42  |
Jonathon,
There is a way to add to the list. All the drivers implement the ODA
extensions. This may be more work
than you want for your needs.
If you only want to save the properties and reuse you can create a blank
report add your source
and then create a template. Or add them to a library.
Jason
"Jonathon Wyza" <wyzaj@bethelcollege.edu> wrote in message
news:e0ribn$co2$1@utils.eclipse.org...
> In the window that comes right after New Data Source, There is a list of 5
> types of sources (example db, flat file, jdbc etc) Is there a way to add
> another option to this list. For example I use the same source for most
> of my reports but I don't want to copy and paste the source over and over
> again in each report, nor do I want to recreate the settings each time.
> Or is there a way to make a data source default for the whole project?
> Thanks in advance
> Jonathon
FUDForum. Page generated in 0.03343 seconds
