new class wizard [message #150313] |
Sat, 29 April 2006 15:26 |
Originally posted by: akadanitan.yahoo.com
I am trying to create a new class that implements the java.sql.Driver
interface. I choose "New..." then "Class" and enter a class name, then
click the "Add" button to add an interface to be implemented. However,
when I type: "java.sql" nothing is returned. It seems that I need
something set so that eclipse knows about the standard java
packages--where is that setting? I have the latest JRE in my build path...
Re: new class wizard [message #150327 is a reply to message #150313] |
Sat, 29 April 2006 18:14 |
Someone on IRC told me the answer. Typing just "Driver" will find
java.sql.Driver. Typing "java.sql" and "java.sql." will not. Apparently,
with 3.2RC2 typing "java.sql" will not work whereas "java.sql." will.
FUDForum. Page generated in 0.07886 seconds
