Home » Archived » BIRT » multiple parameter passing problem
multiple parameter passing problem [message #150077] |
Sat, 01 April 2006 00:45  |
I want to pass comma separeted values as parameter. example
my sample query is like
Select * from tbProduct where productCategoryID in ( ? );
and i want to pass multiple category codes through a parameter ex.
ParamCategory=1,2,3,5,7,44 which are also dynamic.
Solve my Problem
Re: multiple parameter passing problem [message #151178 is a reply to message #150077] |
Wed, 05 April 2006 15:02  |
Originally posted by: twindham.ugaais.com
Manoj,
This is kind of a hack, but it was suggested to me by Jason Weathersby:
It's rumored that future versions of BIRT will handle a list of parameter
values nicely, but this works just fine in the mean time.
In my example, I solved the problem of needing two IN parameter lists.
Put the code below in the script section of the report in the beforeOpen
method that
shows up when the DataSet is selected in the Outline view in Eclipse.
this.queryText = "SELECT " +
"Agent_Entity_ID, " +
"Agent_First_Name, " +
"Agent_Last_Name, " +
"State_ID, " +
"Company_ID, " +
"Agency_Name, " +
" FROM SomeTable " +
" WHERE Company_ID = 1 ";
if(params["agentID"] != null) {
this.queryText += " AND dbo.SomeTable.Agent_Entity_ID IN (" +
params["agentID"] + ")";
if(params["stateID"] != null) {
this.queryText += " AND dbo.SomeTable.State_ID IN (" +
params["stateID"] + ")";
The report has to have report parameters defined "agentID" and "stateID" and
both parameters have the property "Allow null vlaue" checked. So, now you
can pass 0 or more parameters in the url like in the following examples:
http://localhost:8080/birt/frameset?__report=reportName.rptd esign&agentID='0000025046','0000345234'&stateID='17','3'
http://localhost:8080/birt/frameset?__report=reportName.rptd esign&stateID='17','3'
Good luck,
Trace Windham
email me if you have questions about this, twindham@gmail.com
"Manoj Herkar" <mgherkar@gmail.com> wrote in message
news:a07b2e07ee10037e34cb3d265af85cd9$1@www.eclipse.org...
> Hello,
> Solve my Problem
Current Time: Wed Jul 16 08:59:47 EDT 2025
Powered by FUDForum. Page generated in 0.08037 seconds
