Home » Language IDEs » C / C++ IDE (CDT) » Hacking error messages
Hacking error messages [message #150073] |
Tue, 26 July 2005 20:24  |
We're using Green Hills compilers to compile C code. Eclipse doesn't
understand Green Hills error messages, so I have to read the console
output to find my errors and I can't just click on a "Problem" entry to
jump to the error.
I *could* write an error parser for the Green Hills compiler, but that
would require me getting elbow-deep in Eclipse development and I'm a
total n00b (not a Java n00b, just an Eclipse n00b).
Or, I could write a filter using sed scripts or awk or something to put
Green Hills error messages in a format that Eclipse knows about...
Or so I thought... I tried writing a test program and looking at gcc's
output. I'm pretty sure this is a hopeless idea.
Does anyone have anything heartening to tell me? Or is this line of
inquiry as doomed as it appears to be?
Has anyone actually written a Green Hills error parser that is (so far)
invisible to Google?
Re: Hacking error messages [message #150180 is a reply to message #150073] |
Wed, 27 July 2005 17:33   |
--------------050009000303020407060301
Actually - I was wrong. It's not too bad. For those of you who happen to
use Green Hills and Eclipse, the script is attached.
My understanding is that Green Hills is actually a bit hostile to
Eclipse. I'd be curious to know if there actually *is* anyone who uses
them together (besides me).
name="MyBuilder"
Content-Disposition: inline;
filename="MyBuilder"
# This script builds Green Hills projects and converts the messages to a form
# the Eclipse GCC error parser can recognize.
# The following excerpt comes from GCCErrorParser.java:
# // Known patterns.
# // (a)
# // filename:lineno: description
# // (b)
# // filename:lineno:column: description
# // (c)
# // In file included from b.h:2,
# // from a.h:3,
# // from hello.c:3:
# // c.h:2:15: missing ')' in macro parameter list
# // (d)
# // In file included from hello.c:3:
# // (e)
# // h.c: In function `main':
# // h.c:41: `foo' undeclared (first use in this function)
# // h.c:41: (Each undeclared identifier is reported only once
# // h.c:41: for each function it appears in.)
# // h.c:41: parse error before `char'
# // h.c:75: `p' undeclared (first use in this function)
# From what little experience I've had with the Green Hills C compiler, it
# introduces messages with a line of the following format:
# <file>, line <line>: <type> #<ID>: <message>
# Where:
# <type> is "error" or "warning" or something.
# <ID> is an identifier for the given message.
# Example:
# "main.c", line 42: error #69-D: stupid mistake
# The Green Hills programs seem to wrap long error messages to following lines.
# For example:
# "main.c", line 42: error #69-D: This is a long explanation
# of the stupid mistake you made.
# stupid ?= mistake;
# It appears that the only way you can find the end of the message is to look
# for the line that contains nothing but white space and the caret (^). That
# line, and the previous line are not actually part of the message.
# Global Variables
# Usage.
Usage="$0 [<GHArgs> ... ]"
# The path to the GHS gbuild command.
GHSBuilder='C:/GHS/arm407/gbuild.exe'
# This is the master pattern output lines that introduce a message.
# \1: File
# \2: Line number
# \3: Message type
# \4: Message ID
# \5: Message
MasterPattern='^"\([^"][^"]*\)", line \([0-9][0-9]*\): \([a-z][a-z]*\) #\([^:][^:]*\): \(.*\)$'
# Build, and pipe the output to sed.
${GHSBuilder} $@ 2>&1 |\
sed -n -e "
# Check if this line introduces a message. If not, print this line and move
# on to the next.
/${MasterPattern}/!{
p
b
# If control arrives here, this line is a message. Copy this line to the
# hold space.
h
# The current line is safely tucked away in the hold space. We now want to
# accumulate lines until we find one that contains nothing but white space
# and a caret.
:Accumulate
# Get the next line and append it to the hold space. Note that this
# inserts a newline character, which will be handy later.
n
H
# If the current line contains nothing but white space and a caret,
# we're done accumulating.
/^[ ]*^[ ]*/b FinishedAccumulating
# Go back for more.
b Accumulate
:FinishedAccumulating
# When control arrives here, we've finished accumulating everything in the
# hold space. We can now start pulling stuff back out. Copy the hold space
# to the pattern space.
g
# Remove the source code and caret lines from the pattern space.
s/\(.*\)\n.*\n.*/\1/
# Remove all newlines.
s/\n//g
# Remove redundant spaces.
s/ */ /g
# Reformat this message to GCC pattern (a).
s/${MasterPattern}/\1:\2: \5/g
# Print the re-formatted message. Eclipse should be able to recognize this.
p
# We don't want to throw away the source code and caret lines. Retrieve the
# hold space again.
g
# Remove all but the source code and caret lines from the pattern space.
s/.*\n\(.*\n.*\)/\1/
# Print the source code and caret lines.
p
--------------050009000303020407060301--
Re: Hacking error messages [message #150249 is a reply to message #150180] |
Thu, 28 July 2005 18:01   |
--------------020203040002080902000401
A greatly improved version.
name="MyBuilder"
# // (a)
# // (b)
# // (c)
# // from a.h:3,
# // (d)
# // (e)
# Also, if the GCC parser sees a message description that begins with the word
# "Warning" or "warning", it will remove that word from the message and create a
# warning marker. Otherwise, it will create an error marker.
# Where:
# Example:
# For example:
# line and the previous line are not actually part of the message.
# From what little experience I've had with the Green Hills linker, it
# [elxr] (<type>) <description>
# Where:
# Example:
# [elxr] (error) symbol frob.borz.bix multiply defined in
# plen.o
# garsh.o
# Global Variables
# Usage.
GHSBuilder='C:/GHS/arm407/gbuild.exe -noreasons'
# This is the pattern for output lines that introduce compiler messages.
# \1: File
# \2: Line number
# \3: Message type
# \4: Message ID
# \5: Message
CompilerMasterPattern='^"\([^"][^"]*\)", line \([0-9][0-9]*\): \([a-z ][a-z ]*\) #\([^:][^:]*\): \(.*\)$'
CompilerWarningPattern='^"\([^"][^"]*\)", line \([0-9][0-9]*\): warning #\([^:][^:]*\): \(.*\)$'
# This is the pattern for output lines that introduce linker messages.
# \1: Message type
# \2: Message
LinkerPattern='^\[elxr\] (\([a-z ][a-z ]*\)) \(.*\)$'
# Banners.
CompilerWarningBanner='i\
==== Compiler Warning ================================================\
CompilerErrorBanner='i\
==== Compiler Error ==================================================\
LinkerErrorBanner='i\
==== Linker Error ====================================================\
# Build and pipe the result to sed.
tr -d '\r' |\
sed -n -e "
# Check if this line introduces a compiler message.
/${CompilerMasterPattern}/{
# hold space.
h
# to accumulate lines until we find one that contains nothing but white
# space and a caret.
:CompilerAccumulate
n
H
/^[ ]*^[ ]*\$/b CompilerDone
# Go back for more.
b CompilerAccumulate
:CompilerDone
# the hold space. We can now start pulling stuff back out. Copy the hold
# space to the pattern space.
g
s/\n//g
s/ */ /g
# Figure out what kind of message this is.
/${CompilerWarningPattern}/{
# If control arrives here, this is a warning message. Print the
# corresponding banner.
${CompilerWarningBanner}
# Reformat this message and insert "warning" at the beginning of the
# description. The GCC error parser will remove the string and
# create a warning marker.
s/${CompilerMasterPattern}/\1:\2: warning \5/
# Branch off and print the message.
b PrintCompilerMessage
# Reformat the message.
${CompilerErrorBanner}
s/${CompilerMasterPattern}/\1:\2: \5/
# Control arrives here when we're ready to print the compiler message.
:PrintCompilerMessage
# this.
p
# the hold space again.
g
p
# Go back for more.
b
# Check if this line introduces a linker message.
/${LinkerPattern}/{
# Control arrives here if another linker message terminated the previous
# one.
: AnotherLinkerMessage
# hold space.
h
# to accumulate lines until we find something that terminates this
# message.
:LinkerAccumulate
# Get the next line.
n
# Two things will terminate a linker message:
# 1) Another linker message.
# 2) A blank line.
/${LinkerPattern}/b LinkerDone
/^[ ]*\$/b LinkerDone
# If control arrives here, this line belongs to the message we've
# already started. Append it to the hold space. Note that this
H
# Go back for more.
b LinkerAccumulate
:LinkerDone
# the hold space. We can now start pulling stuff back out. Swap the hold
# and pattern space. We swap, instead of just copying the hold space to
# the pattern space, because the pattern space may now actually hold the
# first part of the next linker message.
x
# Print the message.
${LinkerErrorBanner}
p
# Swap the hold and pattern space again.
x
# Now, the pattern space contains the line that terminated the current
# message. If it's a blank line, then go back to scanning messages.
/^[ ]*/b
# If control arrives here, we have the first line of another linker
# message in the pattern space. Go back to process it.
b AnotherLinkerMessage
# If control arrives here, this line is not part of a message. Print it and
# go back for more.
p
--------------020203040002080902000401--
Re: Hacking error messages [message #150282 is a reply to message #150073] |
Fri, 29 July 2005 04:00  |
In article <dc6k85$hpp$1@news.eclipse.org>, pturley@pturley.com says...
> jump to the error.
It is really not too complicated to write an error parser for Eclipse.
I've done it and I'm new to Eclipse and to Java.
You have to write a plugin which requires the
org.eclipse.cdt.core and extends the "ErrorParser" extention point.
Copy the VCErrorParser.jave file and modify it to your needs.
Hope this helps
Klaus
Current Time: Sat Aug 30 23:08:46 EDT 2025
Powered by FUDForum. Page generated in 0.03527 seconds
