Home » Archived » DSDP » Remote Indexing
Remote Indexing [message #14014] Fri, 16 May 2008 05:50 Go to next message
I have developed a plugin by extending RSE and CDT which understands the
environment here. Also provided compile option.
Now I am trying to induce indexing facilities.
Problem due to which I can not go for CDT local indexing –
- Since I am dealing with remote resources, either maintaining local copy
of project or creating a remote project and indexing it, takes lot of
bandwidth and time.
Solution I thought of – Remote Indexing.
I am going through the documents related with remote indexing.
Please suggest if I am going for the right solution and if can have any
other solution.
I am also thinking of trying out some POC so please direct me with any
material, instructions, guidelines or any help document.
As I was going through the link
http://wiki.eclipse.org/PTP/planning/remote
I also found that some prototyping work on remote indexing has done. I
would be grateful if that can be shared.
Since there is not much of documentation available, I am stuck and really
hoping for reply.
Thanks in advance.
- Vrushali.
Re: Remote Indexing [message #14053 is a reply to message #14014] Mon, 19 May 2008 11:21 Go to previous message
It looks like some work on this will be contributed to PTP.
Please ask on the ptp-dev mailing list or the org.eclipse.tools.ptp
newsgroup.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Vrush wrote:
> Problem due to which I can not go for CDT local indexing ? - Since I
> am dealing with remote resources, either maintaining local copy of
> bandwidth and time.
> Solution I thought of ? Remote Indexing.
> other solution.
> really hoping for reply. Thanks in advance.
> - Vrushali.
Re: Remote Indexing [message #571954 is a reply to message #14014] Mon, 19 May 2008 11:21 Go to previous message
newsgroup.
Vrush wrote:
> bandwidth and time.
> other solution.
> - Vrushali.
Previous Topic:Minimize/Maximize buttons on title bar not working
Next Topic:DSDP projects used in your commercial products
Current Time: Sat Jul 05 07:34:53 EDT 2025
Powered by FUDForum. Page generated in 0.44525 seconds
