JAX-WS 2.0 [message #14004] |
Mon, 04 August 2008 16:06  |
The ORMF project requires JAX-WS 2.0. I would be happy to bundle this
for Orbit if it is wanted. Can I get my CQ and an Orbit CQ approved in
parallel or should I get usage of the libraries approved before
starting a process with Orbit.
All the best,
Joel
Joel Rosi-Schwartz
Etish Limited [http://www.etish.org]
/ o,o \ The proud parents of Useme and the
|) ::: (| Open Requirements Management Framework
====w=w==== [http://www.eclipse.org/ormf]
Re: JAX-WS 2.0 [message #14028 is a reply to message #14012] |
Tue, 05 August 2008 11:43   |
On 2008-08-04 21:27:03 +0100, Chris Aniszczyk <zx@code9.com> said:
> Joel Rosi-Schwartz wrote:
> You can do both at the same time. I'd file the CQ for JAX-WS 2.0
> against ORMF first, than a CQ in Orbit for reuse of the previous CQ.
> Cheers,
> ~ Chris
Thanks Chris, will do. I am waiting on the answer to a question I asked
the emo-ip team, but perhaps you know the answer. Here is the question
as I posed it:
Before I start filling out a CQ I would like your advice on how to
structure it. JAX-WS is a standard Java 5 EE component that is
developed as a part of Glassfish here. It is distributed as a
single executable jar file that installs as a hierarchy which contains
16 jar files. The source for JAX-WS is also distributed as a
single executable jar file that installs as a hierarchy, but the source
for all target jars are in a unified tree. Is it possible to have the
entire library approved in one go or do I have to fill in 16 CQ? If I
need to do 16 CQ, should I create a 17th that contains the source and
point all of the other to it or attach a copy of the source to each?
Can you advise on this or should I wait for an answer from them?
Joel
Joel Rosi-Schwartz
|) ::: (| The Open Requirements Management Too
====w=w==== [https://useme.dev.java.net]
Re: JAX-WS 2.0 [message #564044 is a reply to message #14004] |
Mon, 04 August 2008 16:27  |
> parallel or should I get usage of the libraries approved before starting
You can do both at the same time. I'd file the CQ for JAX-WS 2.0 against
~ Chris
Re: JAX-WS 2.0 [message #564064 is a reply to message #14012] |
> Cheers,
> ~ Chris
as I posed it:
Joel
Joel Rosi-Schwartz
Re: JAX-WS 2.0 [message #564094 is a reply to message #14028] |
Tue, 05 August 2008 12:05  |
I'd wait on what the IP team has to say.
It depends what those 16 folders are... if it's just all source
representative of JAX-WS than 1 CQ should be enough. However, if those
16 folders represent JAX-WS dependencies than that could be an issue and
require separate CQs.
Good luck!
~ Chris
Re: JAX-WS 2.0 [message #564110 is a reply to message #14043] |
Tue, 05 August 2008 16:32  |
> and require separate CQs.
> Good luck!
> Cheers,
> ~ Chris
Chris,
I am having an on going conversation with Sharon Corbett on this. I am
going to add you to the CC list as I think you might want to express
your opinion from the Orbit perspective.
/joel
Joel Rosi-Schwartz
FUDForum. Page generated in 0.11042 seconds
