| JSP Editor code-complete in non DynamicWeb project [message #149988] |
Wed, 30 November 2005 15:25  |
Hi htere,
Does anybody see this same behavior as I see?
I have a regular (legacy) Java project, including some JSP files. It
does not recognize the custom taglibs in the editor, but that is
mentioned before.
However, when I edit Java code in scriptlets and try to use code
complete, it seems to work fine, except after it completes a code
complete (i.e. Ctrl+<Space> to complete a variable or method), it jumps
a certain amount down in the code (about 30+ lines). It does the right
completion, but seems to get confused about its cursor position afterwards.
This behavior is off course quite annoying and renders cod completion
quite useless.
Kind regards
K<o>
| Re: JSP Editor code-complete in non DynamicWeb project [message #150872 is a reply to message #150764] |
Tue, 06 December 2005 01:58  |
Originally posted by: marx.nospam_wasko.pl
Użytkownik Exquisitus napisał:
>>But another bug is that in such project in jsp file syntax
>>checking doesn't see includes and variables defined there.
> Yes I have the same problem. Eclipse 3.1.1, Webtools 0.7.1.
> Will this be fixed in the 1.0 release as well? :)
i hope, but there is no open bug about it
Marx
FUDForum. Page generated in 0.04229 seconds
