| Weird 'parameter' effect [message #149962] |
Fri, 31 March 2006 08:37  |
Originally posted by: tzeeman.sogyo.nl
Following the screencast "Using data set parameters and report
parameters." in the BIRT tutorial section I came across a weird effect.
The report without parameters has a correct list of countries, states and
cities, but after I put in the parameter on country, the shown result
becomes corrupt. The countries are ok (and respect the parameterising), as
are the states. The column with the cities is plain wrong; all records
show the city belonging to the first record.
Example (paramter is 'A%'):
COUNTRY STATE CITY
Australia NSW Chatswood
Australia Queensland Chatswood
Australia Victoria Chatswood
Austria Chatswood
Austria Chatswood
31-mrt-2006 15:36
Does anyone have an idea what could be going wrong?
regards,
Thomas
| Re: Weird 'parameter' effect [message #150184 is a reply to message #150169] |
Mon, 03 April 2006 05:11  |
OK. Tried again and this time I started out with only the country and city
columns; first without params, which worked, and then with params, which
worked too. Afterwards I added the state and now the entire thing works.
I can't find a difference between the two reports, but one works and the
other doesn't ?:( Totally weird.
Thomas
FUDForum. Page generated in 0.03580 seconds
