Home » Language IDEs » Java Development Tools (JDT) » javadoc popup for external libraries
javadoc popup for external libraries [message #149938] Fri, 19 March 2004 12:05 Go to next message
Originally posted by: obon.gmx.net
I have no problems getting javadoc popups for the classes included in the
source folders of my project.
But for the classes from external libraries, such as JRE, I get popups
without any javadoc, just the method name and return type. I specified the
"Javadoc location", and it is local on my Hard disk. But it doesn't help.
I don't get more information even when I press F2.
For code completion I get no javadoc popups at all for external classes.
Any ideas what else can be configured?
I use Eclipse 2.1.1 under Win2000.
TIA
Oleg
Re: javadoc popup for external libraries [message #149961 is a reply to message #149938] Fri, 19 March 2004 15:36 Go to previous messageGo to next message
Hi, perhaps I'm wrong but I believe that you need to attach a source file
to the class.
Thanks.
"Oleg" <obon@gmx.net> wrote in message news:c3f980$9h6$1@eclipse.org...
> Hello,
> TIA
> Oleg
Re: javadoc popup for external libraries [message #150128 is a reply to message #149961] Mon, 22 March 2004 03:45 Go to previous messageGo to next message
Thanks for the suggestion, Jose, it works, but I think it should also be
sufficient just to attach the javadoc. It's inexplicable for me why not.
Oleg
> to the class.
> Thanks.
> > Hello,
> > TIA
> > Oleg
Re: javadoc popup for external libraries [message #151523 is a reply to message #150128] Tue, 30 March 2004 04:19 Go to previous messageGo to next message
It's also possible to attach Javadoc which you can then browse using
"Open External Javadoc" (Shift+F2) or by pressing F1 and then select
"Javadoc <selected element>"
HTH
Dani
>Oleg
>>to the class.
>>Thanks.
>>>Hello,
>>>TIA
>>>Oleg
Re: javadoc popup for external libraries [message #169445 is a reply to message #151523] Tue, 20 July 2004 00:06 Go to previous messageGo to next message
Originally posted by: steve.golftime.com.au
I have librarys that are binary releases and only have the jar files and
the java doc.
Is it possible to configure the code assist popups to use the javadoc to
determine their content?
Steve
>> not.
> HTH
> Dani
>> Oleg
>>> source file
>>> to the class.
>>> Thanks.
>>>> Hello,
>>>> in the
>>>> specified the
>>>> help.
>>>> classes.
>>>> TIA
>>>> Oleg
Re: javadoc popup for external libraries [message #169463 is a reply to message #169445] Tue, 20 July 2004 03:34 Go to previous message
Originally posted by: markus_keller.ch.ibm.spam.protect.com
> the java doc.
No. See feature request https://bugs.eclipse.org/bugs/show_bug.cgi?id=41421
Markus
Previous Topic:Difference Eclipse 3.0 vs Eclipse 2.1 : Code Formatting - Line Wrapping
Next Topic:Breakpoints Not Highlighted in Editor
Current Time: Mon Jul 21 22:04:16 EDT 2025
Powered by FUDForum. Page generated in 0.17938 seconds
