CDT RC2 Debug/Launch Bugs [message #149868] |
Sat, 23 July 2005 05:35  |
Originally posted by: dev.jonw.f2s.com
For a while I have been using Eclipse 3.0 / CDT2.x to drive gcc/gdb for my
remote m68k target with the following setup:
Win2000 Pro SP4
Cygwin 1.5.12
GNU toolchain crossed for m68k-elf
binutils 2.15
m68k-elf-gcc 3.4.1
m68k-elf-gdb 6.2.1
....using slightly modified m68k gdb-stub for debugging.
I have moved from CDT 2.1 to 3.0 and Eclipse3.1, and although there are some
excellent improvements (particularly in the source parser) I have come
across the following problems (most serious first).
(Have tested with 3.0.M7 and 3.0.RC2 - all a present in both - 2.1.1 had
none).
* Breakpoints not cleared at target:
When I clear breakpoint in the editor it is not cleared in the target (in
every case).
i.e. the target still breaks despite the breakpoint being clear in eclipse.
I have to reload the code to remove them.
All the other stuff that issues breakpoints to the target (e.g. Run to Line)
is OK.
* Lengthy source lookup warnings on Launch
When launching, the source search seems to get confused (but it still works
OK once going).
If there are a number of search paths the launch time is considerably
increased.
E.g.: I get this lot in the console when launching:
Warning: /cygdrive/d/Dev/M68C-elf/bios5/5v00/D: No such file or directory.
Warning: \cygwin\usr\src\gcc-3.4.1\gcc\config\m68k: No such file or
directory.
Warning: \cygwin\usr\src\newlib-1.13.0\newlib\libc\unix: No such file or
directory.
Warning: \cygwin\usr\src\newlib-1.13.0\newlib\libc\time: No such file or
directory.
Warning: \cygwin\usr\src\newlib-1.13.0\newlib\libc\syscalls: No such file or
directory.
....loads more...
....and finally
Warning: \Dev\M68C-elf\bios5\5v00\.settings: No such file or directory.
Warning: \Dev\M68C-elf\bios5\5v00: No such file or directory.
Warning: /cygdrive/d/Dev/M68C-elf/bios5/5v00/-r: No such file or directory.
Source lookup is set for:
Default: - D:\Dev\M68C-elf\bios5\5v00
m68k - D:\cygwin\usr\src\gcc-3.4.1\gcc\config
libc - D:\cygwin\usr\src\newlib-1.13.0\newlib
It looks as though the launcher is confusing cygwin paths and Windows
paths - is this just a setup issue??
* 'Internal Error: Failed to fetch children from target'
Get the above message spuriously during debugging... I get no details and
the debugger seems to continue working after the message box is dismissed.
* Double click to change register values.
Double clicking on a register no longer brings up the 'Change Value' dialog.
I just seem to get flicker - fine if selected from the context menu.
Has anybody else come across these?
If nobody recognizes them I'll slap them in bugzilla.
John.
Re: CDT RC2 Debug/Launch Bugs [message #149900 is a reply to message #149868] |
Sun, 24 July 2005 15:39  |
Originally posted by: mikhailkhod.rogers.com
Please, see my comments inline.
"John Wilson" <dev@jonw.f2s.com> wrote in message
news:dbt31u$n6f$1@news.eclipse.org...
> Win2000 Pro SP4
> Cygwin 1.5.12
> binutils 2.15
> m68k-elf-gcc 3.4.1
> m68k-elf-gdb 6.2.1
some
> none).
> every case).
eclipse.
Line)
> is OK.
I can't reproduce it, but there are other complains about breakpoints not
being cleared in the target. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=103567
works
> OK once going).
> increased.
> directory.
> directory.
> directory.
or
> directory.
> ...loads more...
> ...and finally
directory.
Set the mi protocol level to 1. To do this, go to the "Debugger" page of the
launch configuration dialog and open the "Advanced" dialog. This should fix
the problem.
There are changes in the Eclipse Debug platform implementation comparing to
Eclipse 3.0. I suspect this type of errors are caused by race conditions,
but unfortunately I don't have a reproducable case.
dialog.
I wasn't aware this feature existed in Eclipse 3.0. If you feel that it is
important, file a bug against Platform Debug.
> John.
FUDForum. Page generated in 0.02245 seconds
