Home » Eclipse Projects » GEF » Redbook example error - Unable to create part:
Redbook example error - Unable to create part: [message #149511] Tue, 31 August 2004 14:52 Go to next message
Originally posted by: jsk_lam.hotmail.com
I have Eclipse 3.0 running "org.eclipse.draw2d_3.0.1" and
"org.eclipse.gef_3.0.1". I also ported the redbook Network example (see
chapter 5, p. 167) to run on this new build. However, I got the following
errors when running the Network example:
Error: "Unable to create part:"
The same example runs greate on Eclipse 3.0 with
"org.eclipse.draw2d_3.0.0" and "org.eclipse.gef_3.0.0"
Does anyone has the clue?
SL
Re: Redbook example error - Unable to create part: [message #149520 is a reply to message #149511] Tue, 31 August 2004 17:17 Go to previous messageGo to next message
What does the error log have to say about this? (Windows -> Show View ->
Other -> PDE Runtime -> Error Log)
"SL" <jsk_lam@hotmail.com> wrote in message news:ch2hdq$h2q$1@eclipse.org...
> Thanks
> SL
Re: Redbook example error - Unable to create part: [message #149523 is a reply to message #149520] Tue, 31 August 2004 18:03 Go to previous messageGo to next message
Hi Pratik,
I have sent you 2 error log files, one is from the development workspace,
and the other is from the runtime workspace environment.
Sang
> > Thanks
> > SL
Re: Redbook example error - Unable to create part: [message #149534 is a reply to message #149523] Wed, 01 September 2004 04:14 Go to previous messageGo to next message
Originally posted by: g.wagenknecht.planet-wagenknecht.de
SL wrote:
> Hi Pratik,
> workspace, and the other is from the runtime workspace environment.
You should send the complete stack to this newsgroup.
Cu, Gunnar
Re: Redbook example error - Unable to create part: [message #149536 is a reply to message #149523] Wed, 01 September 2004 04:14 Go to previous messageGo to next message
SL wrote:
> Hi Pratik,
You should send it to the newsgroup to allow others also to view the stack
trace of the exception.
Cu, Gunnar
Re: Redbook example error - Unable to create part: [message #149630 is a reply to message #149523] Wed, 01 September 2004 13:05 Go to previous message
java.lang.IllegalArgumentException: This container can not contain this type
of child: $Palette Tool
at org.eclipse.gef.palette.PaletteContainer.add(PaletteContaine r.java:77)
at org.eclipse.gef.palette.PaletteContainer.add(PaletteContaine r.java:67)
com.ibm.itso.sal330r.network.editor.NetworkPaletteRoot.<init >(NetworkPalette
Root.java:65)
com.ibm.itso.sal330r.network.editor.NetworkEditor.getPalette Root(NetworkEdit
or.java:662)
I am not familiar with the network example, but it seems that an attempt is
being made to add a tool directly to the palette root (in NetworkPaletteRoot
constructor). The tool needs to be put inside a group or drawer. This has
always been the recommended way of putting tools in the palette. Now,
apparently, there are checks in place to prevent incorrect behaviour.
So, to fix this problem, create a group or drawer and put the tools inside
that. Look at LogicPlugin#createPalette() if you are not sure how to do
that.
BTW, these checks were added before the 3.0 release. You had a 3.0
integration build that was not the final 3.0 release.
"SL" <jsk_lam@hotmail.com> wrote in message news:ch2sja$2gm$1@eclipse.org...
> Hi Pratik,
> Thanks
> Sang
View ->
(see
following
> > > Thanks
> > > SL
Previous Topic:GEF 3.0 Installed but not in my plug-in list?
Next Topic:Tutorials of GEF with examples
Current Time: Thu Jul 17 22:28:14 EDT 2025
Powered by FUDForum. Page generated in 0.09820 seconds
