| parameter names [message #149510] |
Mon, 28 November 2005 03:39  |
When using eclipse to override/implement the doGet method, it is implemented
with parameters named 'arg0' and 'arg1'.
What should I do to make it recognize their names ('request' and
'response')?
| Re: parameter names [message #149548 is a reply to message #149531] |
Mon, 28 November 2005 10:30  |
Originally posted by: mvdb.ibl-software.nl
To be honest : I get a lof of errors in eclipse, but I never had any
errors attaching source to a jar dependency, so I think you did
something really weird...
You should attach the source to Project/Properties/Build Path (or
whereever you javax.servlet.* jar is, and attach the source of
javax.servlet.* there..
Mvgr,
Martin
Zohar wrote:
> When I try doing that I get an error with this exception in the log:
> !ENTRY org.eclipse.jdt.ui 4 10001 2005-11-28 15:37:28.702
> !MESSAGE Internal Error
> !STACK 0
> java.lang.reflect.InvocationTargetException
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:327)
> at
> org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:447)
> at
> org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.r un(ProgressMonitorJobsDialog.java:261)
> at
> org.eclipse.ui.internal.progress.ProgressManager$3.run(Progr essManager.java:861)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
> at
> org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:895)
> at
> org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:871)
> at
> org.eclipse.ui.internal.progress.ProgressManager.run(Progres sManager.java:1070)
> at
> org.eclipse.jdt.internal.ui.preferences.SourceAttachmentProp ertyPage.performOk(SourceAttachmentPropertyPage.java:152)
> at
> org.eclipse.jface.preference.PreferencePage.performApply(Pre ferencePage.java:426)
> at
> org.eclipse.jface.preference.PreferencePage$2.widgetSelected (PreferencePage.java:280)
> at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
> at org.eclipse.jface.window.Window.open(Window.java:787)
> at
> org.eclipse.jst.common.navigator.internal.actions.PropertyDi alogAction.run(PropertyDialogAction.java:188)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
> at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
> at
> org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
> at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
> at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
> at org.eclipse.core.launcher.Main.run(Main.java:973)
> at org.eclipse.core.launcher.Main.main(Main.java:948)
> Caused by: java.lang.NullPointerException
> at
> org.eclipse.jst.server.core.internal.RuntimeClasspathContain erInitializer.requestClasspathContainerUpdate(RuntimeClasspa thContainerInitializer.java:85)
> at
> org.eclipse.jdt.internal.ui.wizards.buildpaths.BuildPathSupp ort.requestContainerUpdate(BuildPathSupport.java:208)
> at
> org.eclipse.jdt.internal.ui.wizards.buildpaths.BuildPathSupp ort.updateContainerClasspath(BuildPathSupport.java:191)
> at
> org.eclipse.jdt.internal.ui.wizards.buildpaths.BuildPathSupp ort.modifyClasspathEntry(BuildPathSupport.java:170)
> at
> org.eclipse.jdt.internal.ui.wizards.buildpaths.SourceAttachm entBlock$1.run(SourceAttachmentBlock.java:580)
> at
> org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
> Root exception:
> at
> at
> at
> at
> at
> at
> "Martin van den Bemt" <mvdb@ibl-software.nl> wrote in message
> news:dmehav$1u9$1@news.eclipse.org...
>>Attach the source (maybe javadoc will also do, don't know that) to the
>>servlet jar.
>>Mvgr,
>>Martin
>>>implemented with parameters named 'arg0' and 'arg1'.
>>>'response')?
FUDForum. Page generated in 0.05794 seconds
