create class instances without placing them to the diagram [message #149452] |
Fri, 07 September 2007 05:25  |
I'm wondering if it's possible to create instances of a class without a
graphical representation on a GMF diagram. For example, let say I have the
following model
Root <#>----- Book ----- <#>---- Chapters
I'd like to place a Book element on my GMF editor and add some Chapters to
the book without using a graphical element. I could use a EAttribute
(String[] chapters) in the Book but that's what I want to simulate !.
Actually I can't use a string array cos I transform my model with a JET2
plugin , and JET2 can't read Arrays.
thanks
Tex.
Re: create class instances without placing them to the diagram [message #149460 is a reply to message #149452] |
Fri, 07 September 2007 07:54  |
Tex,
Yes, you can create an instance of Chapter using an EMF command such as CreateChildCommand.
Koji
Subject: create class instances without placing them to the diagram
Date: Fri, 7 Sep 2007 11:25:49 +0200
> Hello,
> following model
> thanks
> Tex.
FUDForum. Page generated in 0.03833 seconds
