Home » Language IDEs » ServerTools (WTP) » targetId for editor contribution to the xml editor
targetId for editor contribution to the xml editor [message #149431] Sun, 27 November 2005 15:10 Go to next message
Originally posted by: schutzerj.hotmail.com
Can anybody tell by what targetId I shall use to add an editor contribution
to the XML editor. I have tried to use the id of the xml editor but then I
cannot get access to the source editor.
Can anybody please help?
Joakim Andersson
Re: targetId for editor contribution to the xml editor [message #149434 is a reply to message #149431] Sun, 27 November 2005 17:06 Go to previous messageGo to next message
Although we still need to comprehensively list all of the available
IDs for 1.0, the current SSE Overview [1] page's "Editor related
IDs" section identifies
org.eclipse.core.runtime.xml.source.EditorContext as the ID for the
source page's context menu. More information about the editors and
the editing framework will ultimately end up there.
1: http://eclipse.org/webtools/wst/components/sse/overview.html
- Nitin
Re: targetId for editor contribution to the xml editor [message #149500 is a reply to message #149434] Mon, 28 November 2005 03:05 Go to previous messageGo to next message
Originally posted by: joakim.bindows.net
Thanks for the quick answer. However I saw this answer in a previous post
but I don't want to add the action to the context menu but rather to the
Edit menu of the workbench and I tried using
org.eclipse.core.runtime.xml.source in the same way as it's done in
plugin.xml for org.eclipse.wst.xml.ui but this didn't work.
/Joakim
"Nitin Dahyabhai" <nitind@us.ibm.com> wrote in message
news:dmdalh$uuj$1@news.eclipse.org...
>> contribution to the XML editor. I have tried to use the id of the xml
>> editor but then I cannot get access to the source editor.
> Although we still need to comprehensively list all of the available IDs
> for 1.0, the current SSE Overview [1] page's "Editor related IDs" section
> identifies org.eclipse.core.runtime.xml.source.EditorContext as the ID for
> the source page's context menu. More information about the editors and
> - Nitin
Re: targetId for editor contribution to the xml editor [message #150390 is a reply to message #149500] Thu, 01 December 2005 16:41 Go to previous messageGo to next message
Originally posted by: amywu.us.DELETETHISPART.ibm.com
You should do something like the following:
<extension point="org.eclipse.ui.editorActions">
<editorContribution
id="org.eclipse.core.runtime.xml.source.editorActions"
targetID="org.eclipse.core.runtime.xml.source">
<action
id="youractionid"
label="youractionlabel"
definitionId="youractiondefinitionid"
tooltip="youractiontooltip"
class="youractiondelegate"
menubarPath="edit/additions">
</action>
</editorContribution>
</extension>
The targetID should be "org.eclipse.core.runtime.xml.source" and make sure
you specify a menubarPath.
"Joakim Andersson" <joakim@bindows.net> wrote in message
news:dmednh$tc9$1@news.eclipse.org...
> /Joakim
section
for
> > - Nitin
Re: targetId for editor contribution to the xml editor [message #150604 is a reply to message #150390] Sat, 03 December 2005 13:55 Go to previous messageGo to next message
Thank but I already tried this and it doesn't work so maybe I should enter
this as a bug.
If you look at the following sample, you can see that it works for the css
editor but not for the xml editor (the real application of course bigger but
you can see the problem from this small sample).
<?eclipse version="3.0"?>
<plugin>
<extension
<editorContribution
id="test"
<action
class="TestAction"
id="testAction"
label="Test Action"
style="push"/>
<editorContribution
id="test"
targetID="org.eclipse.wst.css.core.csssource.source">
<action
class="TestAction"
id="testAction"
label="Test Action"
style="push"/>
</extension>
</plugin>
/Joakim
"Amy Wu" <amywu@us.DELETETHISPART.ibm.com> wrote in message
news:dmnqms$lq8$1@news.eclipse.org...
> <editorContribution
> <action
> id="youractionid"
> </action>
> </extension>
>> /Joakim
> section
> for
>> > - Nitin
Re: targetId for editor contribution to the xml editor [message #150782 is a reply to message #150604] Mon, 05 December 2005 11:47 Go to previous message
Ah, I see the problem now. The problem has to do with the xml editor being
a multipage editor versus just a source editor.
Yes, please open a bug on this, though I'm not sure how easy it will be to
fix this. This may be an Eclipse base limitation.
And in the meantime, you can use the the targetID,
org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part
That's the editor id of the xml editor. This will add your action to the
XML editor (and it will be on for both the design and source page)
However, as you can see by the name, it's not really public API and may be
subject to change.
"Joakim Andersson" <schutzerj@hotmail.com> wrote in message
news:dmspn3$oa6$1@news.eclipse.org...
> this as a bug.
but
> <plugin>
> <extension
> <editorContribution
> id="test"
> <action
> class="TestAction"
> id="testAction"
> label="Test Action"
> style="push"/>
> <editorContribution
> id="test"
> <action
> class="TestAction"
> id="testAction"
> label="Test Action"
> style="push"/>
> </extension>
> </plugin>
> /Joakim
> > <editorContribution
> > <action
> > id="youractionid"
> > </action>
> > </extension>
sure
post
the
> >> /Joakim
xml
IDs
> > section
ID
> > for
and
> >> > - Nitin
Previous Topic:Trying to control editor pop \up based on file..
Next Topic:Implement "Add Import" for jsp
Current Time: Thu Jul 10 00:31:38 EDT 2025
Powered by FUDForum. Page generated in 0.04758 seconds
