Home » Language IDEs » ServerTools (WTP) » Ctrl-J inserts a new-line instead of
Ctrl-J inserts a new-line instead of [message #149429] Sun, 27 November 2005 03:35 Go to next message
Originally posted by: zkoppany.gmx.de
I have just installed 1.-M9 with eclipse-3.1 and everything works except
ctrl-j inserts a new -line (in a xml file) instead of incremental search.
any ideas?
Zsolt
Re: Ctrl-J inserts a new-line instead of [message #149435 is a reply to message #149429] Sun, 27 November 2005 17:16 Go to previous messageGo to next message
> any ideas?
It works fine when I try it. Is there anything different about your
install other than the Eclipse SDK, WTP and it's requirements?
- Nitin
Re: Ctrl-J inserts a new-line instead of [message #149506 is a reply to message #149435] Mon, 28 November 2005 03:21 Go to previous messageGo to next message
I installed everything (listed on the web page) new but my workspace is old.
Zsolt
"Nitin Dahyabhai" <nitind@us.ibm.com> schrieb im Newsbeitrag
news:dmdb82$vjg$1@news.eclipse.org...
>> any ideas?
> - Nitin
Re: Ctrl-J inserts a new-line instead of [message #149556 is a reply to message #149506] Mon, 28 November 2005 11:20 Go to previous messageGo to next message
Did you restart with -clean after doing so? Also, does it work in
other editors such as the plain Text Editor and Java Editor while
failing in the XML Editor?
- Nitin
Re: Ctrl-J inserts a new-line instead of [message #149565 is a reply to message #149556] Mon, 28 November 2005 13:58 Go to previous message
Thank you.
I checked this issue again and I have this problem with eclipse-3.1 but not
width 3.1.1.
Zsolt
news:dmfaoo$arr$1@news.eclipse.org...
>> old.
> Did you restart with -clean after doing so? Also, does it work in other
> editors such as the plain Text Editor and Java Editor while failing in the
> XML Editor?
> - Nitin
Previous Topic:parameter names
Next Topic:WTP 100% when saving resource
Current Time: Fri Jul 18 22:39:10 EDT 2025
Powered by FUDForum. Page generated in 0.66560 seconds
