Home » Archived » BIRT » date parameter
date parameter [message #149228] Wed, 29 March 2006 06:29 Go to next message
Originally posted by: almasalki.hotmail.com
hi for all
how can used parameter from date(datatype)
can you tell me what is the format of the default value, give me an
example,and if I use this default value with quote or without
thanks in advance
Re: date parameter [message #149243 is a reply to message #149228] Wed, 29 March 2006 07:04 Go to previous messageGo to next message
Originally posted by: r.budner.abg.com.pl
Abo Alnnor napisał(a):
> hi for all
> thanks in advance
1. dataset parameter default value (example)(use without quotes):
new Date()
2. report parameters (use without quotes) must follow the format:
MM/DD/YYYY hh:mm:ss AM/PM
for example:
03/29/2006
Re: date parameter [message #149274 is a reply to message #149228] Wed, 29 March 2006 09:37 Go to previous messageGo to next message
> hi for all
> thanks in advance
As a matter of fact I don't know what you mean. Do you ask about
parameters passed in URL or in IDE ??
Re: date parameter [message #149372 is a reply to message #149243] Thu, 30 March 2006 04:15 Go to previous messageGo to next message
thanks
I mean the parameters in the data set,let me expalin
when I write my query, I put this condition in the where clause:
where to_char(reservation.reservation_Date,'01/29/2005')=?
and I define parameter(def_res_date) from datatype(string)and default
value '05/21/2004'.
now in the report parameter, I define the parameter (Res_Date) from
datatype(String) and use it as value to def_res_date
can you help me where is the problem(I use oracle database)
Re: date parameter [message #149395 is a reply to message #149372] Thu, 30 March 2006 08:11 Go to previous message
> thanks
> value '05/21/2004'.
Ok, now it's clear what you want to achieve.
I suggest doing:
1. change where clause to:
WHERE reservation.reservation_date = :p_def_res_date
or
WHERE trunc(reservation.reservation_date) = :p_def_res_date
only if your allow to store time information in
reservation.reservation_date column
2. create dataset parameter
data type: Date Time
direction: Input
Default Value: new Date()
Don't worry about default value, it will be overwritten by reports
parameter value. It is needed to show Preview Results only.
Don't forget about right order of parameter as they appear in the query
text.
3. create report parameter
data type: DateTime
display type: Text Box
Default value: 05/21/2004
Format string as: Custom (you have to change it - press Change... button
and enter format for example: dd-MM-yyyy
or any other that is popular in your country)
And that's it. You have to bind your report parameter with dataset
parameter. Do it on your report item binding tab.
Robert
Previous Topic:Need help: multiple charts by grouping
Next Topic:Own calculations
Current Time: Sat Jul 26 06:00:41 EDT 2025
Powered by FUDForum. Page generated in 0.04711 seconds
