Home » Eclipse Projects » GEF » paint optimization
paint optimization [message #149211] Tue, 31 August 2004 10:56 Go to next message
Originally posted by: david_michonneau.hotmail.com
I believe the DeferredUpdateManager is queuing all the repaint event to have
only repaint called once per modified figure no matter how many times
refreshVisuals has been called. Can you confirm if this is correct, and does
it mean I don't have to worry about firing too many events in my model that
could make the ui blink?
David
Re: paint optimization [message #149226 is a reply to message #149211] Tue, 31 August 2004 11:20 Go to previous messageGo to next message
Yes, more or less. But that doesn't mean that you shouldn't write good code
DeferredUpdateManager marks figures as dirty and repaints them once per
performUpdate() invocation. If anybody's forcing updates anywhere, there
could be multiple paint calls.
"David Michonneau" <david_michonneau@hotmail.com> wrote in message
news:ch23c1$ksi$1@eclipse.org...
have
does
that
> David
Re: paint optimization [message #149539 is a reply to message #149211] Wed, 01 September 2004 04:17 Go to previous messageGo to next message
Originally posted by: g.wagenknecht.planet-wagenknecht.de
> to have only repaint called once per modified figure no matter how
> many times refreshVisuals has been called. Can you confirm if this is
> correct, and does it mean I don't have to worry about firing too many
> events in my model that could make the ui blink?
You can also create our own update manager (inherited from
DeferredUpdateManager) that queues updates during processing a hugh tree of
events...
Cu, Gunnar
Re: paint optimization [message #149583 is a reply to message #149539] Wed, 01 September 2004 10:45 Go to previous messageGo to next message
The default one is already very optimized. It keeps a map of
figures->damage regions, and only when the paint is actually going to occur
does it calculate the clipping of damage (by walking the parent tree and
intersecting rectangles), and then unions the damaged regions to create the
rectangle which needs to be repainted.
"Gunnar Wagenknecht" <g.wagenknecht@planet-wagenknecht.de> wrote in message
news:ch4070$hqq$1@eclipse.org...
of
> events...
> Cu, Gunnar
Re: paint optimization [message #149703 is a reply to message #149539] Thu, 02 September 2004 08:18 Go to previous messageGo to next message
I am interested in that approach, but if I inherit DeferredUpdateManager,
how can I hook it up to the LightweightSystem?
David
of
> events...
> Cu, Gunnar
Re: paint optimization [message #149731 is a reply to message #149539] Thu, 02 September 2004 13:33 Go to previous message
That's incorrect. Painting only occurs once period, not once per-figure.
More specifically, it occurs as soon as the asyncExec is dispatched in
response to the first call to repaint(). So if everything is happening
synchronously in response to a UI event, there is just one repaint.
of
> events...
> Cu, Gunnar
Previous Topic:notification and refreshVisuals
Next Topic:palette question
Current Time: Thu Jul 17 19:55:09 EDT 2025
Powered by FUDForum. Page generated in 0.07141 seconds
