Home » Language IDEs » Java Development Tools (JDT) » Pasting indents inappropriately
Pasting indents inappropriately [message #149147] Wed, 17 March 2004 15:22 Go to next message
What's up with the paste operation? It puts the first line in the correct
position then indents everything else. Any ideas?
TIA,
Rod
Re: Pasting indents inappropriately [message #149593 is a reply to message #149147] Thu, 18 March 2004 03:16 Go to previous messageGo to next message
What build? Can you paste an example?
Smart paste just tries to guess the correct indent for the first two
lines and shifts the remaining lines the same amount as the second line.
The idea behind this is to preserve the original formatting, but shift
the pasted code to the indentation level of where you paste.
-tom
Re: Pasting indents inappropriately [message #150177 is a reply to message #149593] Mon, 22 March 2004 17:45 Go to previous messageGo to next message
Say I cut this:
private void foo()
bar();
When pasting this I get the following bogus indents. First line is correct,
subsequents are not.
private void foo()
bar();
Re: Pasting indents inappropriately [message #151293 is a reply to message #150177] Mon, 29 March 2004 07:41 Go to previous message
this works for me - you probably need to set your code formatter
preferences according to your coding style.
-tom
> Say I cut this:
> private void foo()
> bar();
> private void foo()
> bar();
Previous Topic:TemplateStore
Next Topic:Loading .class file as resource
Current Time: Thu Jul 17 07:52:36 EDT 2025
Powered by FUDForum. Page generated in 0.28094 seconds
