CPL: Must I make the source code to my plugin available? [message #149038] |
Fri, 24 October 2003 09:22  |
CPL: Must I make the source code to my Eclipse plugin available?
In Common Public License (CPL) Frequently asked questions
( http://www-106.ibm.com/developerworks/library/os-cplfaq.html), Question
19, it reads as follows:
-- cut --
If I write a module to add to a Program licensed under the CPL and
distribute the object code of the module along with the rest of the
Program, must I make the source code to my module available in accordance
with the terms of the CPL?
No, as long as the module is not a derivative work of the Program.
-- end cut --
Is an Eclipse plugin a derivative work?
FUDForum. Page generated in 0.08961 seconds
