Home » Language IDEs » Java Development Tools (JDT) » CVS - src/bin
CVS - src/bin [message #13880] Mon, 05 May 2003 12:44 Go to next message
I've set new project parameters to have source and output locations of
src and bin, respectively.
(Windows -> Preferences -> New Project -> folders)
However, when I Checkout as... from the CVS repository perspective, it
does not create these divisions?
How can I accomplish this?
Re: CVS - src/bin [message #14650 is a reply to message #13880] Tue, 06 May 2003 04:18 Go to previous messageGo to next message
> it does not create these divisions?
You can't. There's no transformation support upon checkout. If you
checkout non-eclipse source from an existing CVS repository I suggest to
use "Check Out As..." which allows you to setup the Java build path upon
checkout.
HTH
Dani
Re: CVS - src/bin [message #15077 is a reply to message #14650] Tue, 06 May 2003 11:51 Go to previous messageGo to next message
I do use checkout as, but I was hoping since I set the default to src &
bin, it would set this up. But you are saying I have to do this
explicitly despite the default.
Would it be an unreasonable request, this "transformation" support?
> checkout.
> HTH
> Dani
Re: CVS - src/bin [message #15091 is a reply to message #15077] Tue, 06 May 2003 13:39 Go to previous messageGo to next message
Is there any reason why you can't check the .classpath and .project back
into CVS? It would simplify things tremendously. You won't need to do
Checkout As... It would know automatically the type of project it is.
Rich Kulp
Re: CVS - src/bin [message #15805 is a reply to message #15091] Tue, 06 May 2003 15:29 Go to previous messageGo to next message
Once i get things set up, I will check in the .* files, but I'm not
there yet.
I have just created the repository, and connected to it in eclipse.
It appears that even Checkout As... doesn't work.
When I do this and specify the src & bin folders, the src folder is not
created.
> Rich Kulp
Re: CVS - src/bin [message #15824 is a reply to message #15805] Tue, 06 May 2003 15:52 Go to previous messageGo to next message
IT sounds like the easiest thing is to Check it out, update the
source/bin paths to what you want, and then check them in.
Rich
Re: CVS - src/bin [message #19088 is a reply to message #15824] Fri, 09 May 2003 17:45 Go to previous message
Thanks for your help on this and my other question, Rich, everything is
working now.
> Rich
Previous Topic:Debugging J2ME/MIDP applications
Next Topic:Format source code under the same project
Current Time: Tue Jul 22 02:24:18 EDT 2025
Powered by FUDForum. Page generated in 0.29895 seconds
