Home » Eclipse Projects » GEF » A multiline label with a scroll bar
A multiline label with a scroll bar [message #148781] Fri, 27 August 2004 03:57 Go to next message
Originally posted by: sergeyv.offshorecreations.com
Hello
How to create a multiline label with a scroll bar?
Vyunnikov Sergey
Re: A multiline label with a scroll bar [message #148791 is a reply to message #148781] Fri, 27 August 2004 11:23 Go to previous messageGo to next message
Look at org.eclipse.draw2d.widgets.MultiLineLabel.
"Sergey Vyunnikov" <sergeyv@offshorecreations.com> wrote in message
news:cgmpc6$nji$1@eclipse.org...
> Hello
> Thanks
> Vyunnikov Sergey
Re: A multiline label with a scroll bar [message #148798 is a reply to message #148791] Fri, 27 August 2004 11:30 Go to previous messageGo to next message
I need IFigure not Widget.
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:cgnjfe$6mp$1@eclipse.org...
> > Hello
> > Thanks
> > Vyunnikov Sergey
Re: A multiline label with a scroll bar [message #148814 is a reply to message #148798] Fri, 27 August 2004 13:37 Go to previous message
MultiLineLabel is a widget that hosts a LightweightSystem. Since you
already have a LWS, you just need the "contents" of the LWS in
MultiLineLabel. However, I believe it uses native scrollbars (gotten from
FigureCanvas). You'll have to replace that with a Draw2D scroll pane. So,
in short, create a scroll pane, and set the view to be the same as the
contents of the MultiLineLabel.
news:cgnjsi$7f7$1@eclipse.org...
> > > Hello
> > > Thanks
> > > Vyunnikov Sergey
Previous Topic:How to add PropertySheet?
Next Topic:Accessing source for Logic and Flow examples
Current Time: Sun Jul 27 01:34:23 EDT 2025
Powered by FUDForum. Page generated in 0.03524 seconds
