Home » Modeling » GMF (Graphical Modeling Framework) » Problem with properties
Problem with properties [message #1136] Mon, 31 July 2006 11:59 Go to next message
Originally posted by: bob2.msn.com
I've spent ages trying to implement my own properites for my generated
diagrams but I'm not getting anywhere. I've read the "Take control of your
properties" and "The Eclipse Tabbed Properties View" articles but I still
cant get even a simple property box to work with the message "Properties are
not available".
I've based most of what I've done on the HockeyLeague example and am just
trying to get the name of a node in my diagram to be displayed in the
property box.
I've added the propertyContributor, propertyTabs and propertySections to my
plugin.xml and have copied AbstractStringPropertySection,
AbstractTextPropertySection, HockeyleaguePropertySheetPage and
NamePropertySection, AbstractHockeyleaguePropertySection classes. I've
changed the following to conform with my own diagram:
NamePropertySection's getFeature method uses my own package instead of
HockeyleaguePackage.
In my editor file, it now implements ITabbedPropertySheetPageContributor and
I've added the methods getContibutorId() and getAdapter(Class) as the
article says.
I've only got one property section which uses the class NamePropertySection.
The input to the section has been set to a class in my model which extends
EObject and just has get and set methods for a name.
In the propertySheetPage, it has a method to get the AdapterFactory of the
editor. My editor doesent have an adapterfactory method. Im not entirely
sure what this actually does and if its got any relevance to the properties
not appearing.
Has anyone had any similar problems and know what to do to fix this?
Thanks in advance
Bob
Re: Problem with properties [message #1190 is a reply to message #1136] Mon, 31 July 2006 15:24 Go to previous messageGo to next message
The message "Properties are not available" indicates that no
propertySections match your selection.
I am guessing that you are selecting objects on the diagram, which are
EditParts, yet the <input> in the propertySections specify semantic objects.
I would debug TabbedPropertySheetPage.setInput() to make sure the selection
is as you expect.
You can then look at the typeMapper used in the logic example which
translates between the diagram and the semantic objects.
Cheers...
Anthony
"bob" <bob2@msn.com> wrote in message news:eal995$t9e$1@utils.eclipse.org...
> your
> are
> not available".
> property box.
> my
> and
> article says.
> properties
> not appearing.
> Thanks in advance
> Bob
Re: Problem with properties [message #2674 is a reply to message #1190] Wed, 02 August 2006 12:54 Go to previous messageGo to next message
Thanks for your help. I've managed to get it working now
Re: Problem with properties [message #4353 is a reply to message #2674] Thu, 03 August 2006 06:18 Go to previous messageGo to next message
Originally posted by: netsrujana.rediffmail.com
Hi Bob,
I have been struggling with the properties for a while now, with the GMF
generated code. Could you let me know how you managed to make it work
regards,
Phani Kumar K.
"bob" <bob2@msn.com> wrote in message news:eaql87$vko$1@utils.eclipse.org...
Re: Problem with properties [message #4697 is a reply to message #4353] Thu, 03 August 2006 08:21 Go to previous messageGo to next message
I made it work, the culprit is the TypeMapper
"Phani Kumar Kotaprolu" <netsrujana@rediffmail.com> wrote in message
news:easiho$1bo$1@utils.eclipse.org...
> Hi Bob,
> regards,
> Phani Kumar K.
Re: Problem with properties [message #6687 is a reply to message #4697] Sun, 06 August 2006 07:00 Go to previous message
Yes the TypeMapper was the problem for me aswell.
Previous Topic:New to GMF - help needed
Next Topic:refactoring GMF document support into platform
Current Time: Wed Jul 16 13:40:59 EDT 2025
Powered by FUDForum. Page generated in 0.05686 seconds
